Airbag light flashing!
Old Sep 30, 2008 | 11:02 PM
chunhamujuk's Avatar
I tried to install paddle sihfter... and after taking erverything off i realize that i had diff color... so i put everythnig back... checkd my wheel so it is straight but it wasn't so i had to redo it... after that, my airbag light is flashing... + my engine service light came on... can someone help me please >.<;!
Old Sep 30, 2008 | 11:42 PM
kool_yaar's Avatar
reset the ecu and you should be fine as long as you did not play with any of the SRS wires, which are marked yellow. Eother do the battery method where you loose all your settings and preset or do the peddle reste easier and better.
NOTE: DURING THE ENTIRE PROCESS YOUR CAR SHOULD NOT BE STARTED.
1)turn car to ON position, by pressing ignition button twice without foot on brake/clutch(NOT Start!)
2)Right after you hear the third beep from the car, fully press and release the accelerator pedal 5 times(in-out 5 times)
3)Wait 7 seconds then floor the gas pedal and hold for 10 seconds. After that 10 seconds the SES Light will start to blink slowly.
4) Release the pedal and floor it again and hold for 10 seconds.
After these 10 seconds the SES light will disappear then begin to flash much more rapidly.
After you have done the following turn the car off and then back on. The ECU is now reset!!
- thanks to original poster
Old Oct 1, 2008 | 12:09 AM
from the step 3, my ses light stays on... following the step... done it 30 times... can't figure it out... please help...
Thanks in advance.
Old Oct 1, 2008 | 07:21 AM
kid4now's Avatar
2. If you do have you air bag light stay on this reset proceedure does work. I had to use this procedure.
Courtesy earth0:
Quote:
Turn the key to the on position and watch the airbag light. It should stay solid for 5-7 secs, and then turn off, and then start to flash.
To reset the light, you must turn the key to on, watch the airbag light stay solid for 5-7 secs and as soon as the airbag light turns off, turn the key to the off position (you have to turn the key to off before the airbag light starts to flash, or you must start over). You need to repeat this 5 times. Try to start the car, and hopefully the light will be reset
This does work. What happened is you probably disconnected the airbag with the battery still connected or connected the battery while th airbag was still out.
Good luck.
What do you mean different colors???
__________________
Old Oct 1, 2008 | 08:19 AM
I don't think I disconnected the airbag with the battery still connected nor connected the battery while the airbag was still out.
+, that method doesn't seem to work... I tried that first (first thing came up on google when i searched it).
As for the colors, I have a black interior and i got wheat color.... errr... sooo frustrated...
Is there anything else I can do?
Thanks in advance.
Old Oct 1, 2008 | 05:58 PM
Ok.. updates.... I have fixed the ses light... but as for my airbag... it flashes randomly... alot slower now... alot slower.... Anyone experienced this problem?
Old Oct 1, 2008 | 06:37 PM
kool_yaar's Avatar
You better get that checked by the dealer for free, it could be something serious! as long as you didnt mess with any wiring they should not be able to tell that you opened the steering color.
Old Oct 1, 2008 | 06:41 PM
They should able to fix it for free, right?... b/c i can't do anything at all because of this... >.<:!!!!!
Old Oct 3, 2008 | 12:09 AM
I dont know if any cares but I went to the dealership and they said my airbag needs to be replaced, wires has to be replaced.... all the parts in the wheel... ... not sure how that happen... and they are charging me as well...
I just feel weired that how unhooking the wire for airbag would mess up the whole airbag... oh well...
Thanks for the help.
Old Oct 3, 2008 | 06:45 AM
kid4now's Avatar
Wow, sorry to here that. I just dont believe your dealer though. Im sure the your car is at the dealer so its a done deal but I would get a second opinion. Im not doubting how hard you tried and you skill level to reset it but I can only belive it just needed to be reset properly.
Good luck
Old Oct 3, 2008 | 07:17 AM
fbpem1's Avatar
i have had a few 07+ G's throw the fault for the drivers air bag module, so its a possibility its bad.
Old Oct 3, 2008 | 08:37 AM
kool_yaar's Avatar
Ok, now that you have left the car with them, im not gonna say stuff thats gonna make you feel bad so, i hope everything works out, and how much are they charging you.
Luisgalvan33
Jul 19, 2018 08:16 PM
flytim3
Sep 5, 2015 01:23 PM
leli_11
Aug 10, 2015 08:25 PM
ghost_g35
Aug 7, 2015 10:31 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
