TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
ReCall on 2006 headlamps...
Old Apr 30, 2007 | 08:27 PM
redlude97's Avatar
Originally Posted by Jee_35
if you have a pre-06 coupe but got the 06 headlights, do they still replace them?
No.
Old Apr 30, 2007 | 08:28 PM
redlude97's Avatar
To sum it up, there is no difference in output, its just supposed to fix the cutoff on some cars which was too high on one side, but since some of the tech's don't know what they are doing, you have to go back through and reaim your headlights yourself
Old May 1, 2007 | 09:59 AM
cmrz's Avatar
G35 Coupe
then what is the point of even switching out the lights? why not just keep the originals until a) a headlight goes out or b) you sell the car.
as far as I know the recall does not expire --- am I right on that ?
Old May 3, 2007 | 02:47 AM
JackD's Avatar
When you shine the lights at the wall is it supposed to be one line going across ? One side on my car is higher than the other and I get double lines on other like there were 2 cutoffs.
Old May 3, 2007 | 10:13 AM
cmrz's Avatar
G35 Coupe
I did that test yesterday, shining the lights at my garage door and this is the pattern that I saw.
________/___________/________
or something like that. not really sure what that means.
Old May 3, 2007 | 11:19 AM
shimmy's Avatar
Nice pic!
The reason I'm doing it is b/c the right headlight is not as sharp as my driver's side... not sure if others have this same issue. The cutoff is blurry.
Old May 3, 2007 | 11:53 AM
JackD's Avatar
I got the same thing right side cut of is off and not as sharp as left, the left side seems higher and stronger. And thast is after the recall replacement.
Old May 3, 2007 | 11:09 PM
jpark2479's Avatar
I got mine done and i'm supper pissed. I went through hell taking out the damn city lights on on my originals and when i took it there... they replaced the orange city lights back in. Now I have to go back there and take the damn lights out again!
What was the whole point of this recall by the way?
_______________________
06 White Coupe - Navi - Premium Package - Sports Package - Aero Kit
mbe32
Nov 13, 2015 11:09 PM
alessandro
Oct 8, 2015 09:29 AM
bigmike
Sep 17, 2015 01:58 PM
