TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
TSB repair done free of charge??
Old Sep 12, 2008 | 06:39 PM
reggie11's Avatar
Question TSB repair done free of charge??
I have the rear axle click on my 03 G35 and I am bringing it to the dealer next week. I wasn't sure if TSB repairs were covered by Infiniti or if you had to pay for the repair. I appreciate the help.
Old Sep 13, 2008 | 06:25 AM
whtteg's Avatar
If you are still under warranty they will fix it for free, if not then you would have to pay. If you are out of warranty there is a DIY on here telling how to do it, from reading the DIY it sounds pretty easy as long as you are mechanically inclined.
Old Jan 6, 2009 | 02:52 AM
invisible's Avatar
its not. but i think its only a bolt that needs to be replaced. also, you can purchase the elite plan and have it covered
Old Jan 12, 2009 | 07:48 PM
Rallycraft's Avatar
Pull off the rear wheels, remove the pin and nut in the center of the hub. Take a punch and knock the axle out about half way. Lube the splines with pbc grease or lithium etc. and reassemble. That works everytime for me.
Old Feb 12, 2009 | 07:28 PM
jetdoc's Avatar
Should you not mark the end of the drive shaft and also the hub?
Old Sep 3, 2010 | 09:39 AM
Jaysanity's Avatar
Wow...I thought it was going to be free but they are charging me about 250 for this service and I am currently still under warranty...wtf?? Maybe TSB's are done differently in Canada? Now i gotta pay the checking fee of 61 and change!!!
Old Sep 5, 2010 | 07:32 PM
RogerG35's Avatar
Should be free if your under warranty. Or maybe thats a discounted price?
Old Sep 5, 2010 | 07:40 PM
herrschaft's Avatar
I would just to be safe
Mine was free of charge when I was still under warranty. Don't go to the dealership, search on here for the DIY, if you have the tools it shouldn't be that hard.
Old Sep 27, 2010 | 01:42 AM
rotor7vent2's Avatar
i just did mine today, just took off the 32mm nut on the hub and pushed the axle back... u can reach the splines of the axle from behind the hub... just used a s*it load of moly grease and tightened the nut back on... no need to remove the axle
Old Dec 5, 2010 | 07:57 PM
darnelled's Avatar
Go back and get your refund. If under the bumper to bumper period still, it's free as is everything else that goes wrong with your car.
Thebaws11
Jul 2, 2021 11:36 AM
ara777
Oct 25, 2017 01:45 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
mattdg35
Sep 14, 2015 11:28 AM
ben_m
Engine - Intake/Fuel
Sep 7, 2015 10:04 PM
