TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Passenger Lock Not Working
Old Oct 13, 2008 | 09:02 PM
G-Kid's Avatar
title pretty much says it all...is there a DIY type of thing where i can switch out the battery?
i have to manualy turn the lock for it to open
PITA!
Old Oct 14, 2008 | 02:13 AM
kyle5486's Avatar
im havin the same problem on the passenger side and the door wont open from the outside on that side either if someone has some suggestions it would be very much appreciated
Old Oct 14, 2008 | 02:50 PM
yourdoinitwrong's Avatar
Door lock actuators are a common problem on these cars. If it is just one door doing it then it is not a key fob battery, it is probably the lock actuator. Here is a link to two DIY's for removing the door panel and one for replacing the actuator.
https://g35driver.com/forums/body-in...uator-fix.html
https://g35driver.com/forums/body-in...l-removal.html
If you don't go the $5 route you can buy a new lock actuator from an Infiniti dealer but they aren't cheap. One of the site sponsors would probably get you a decent deal on one. If you are still under warranty just let the dealer take care of everything.
Old Oct 15, 2008 | 07:16 PM
white_dc5's Avatar
The $5 route eventually became a failure. I PM'd the OP of that thread to ask for help and he said the $5 dollar solution didn't last a very long time. I eventually went with OEM nissan actuators for about 130 for each door.
Old Feb 1, 2009 | 03:45 PM
ai_marvin's Avatar
Where can i find oem actuators for 130?
tal1412
Nov 28, 2022 09:25 AM
xluke
Jul 30, 2016 01:48 PM
apintojr
Jul 23, 2015 10:52 AM
