TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Heading to the stealership...
Old Dec 16, 2008 | 11:34 AM
stats's Avatar
Hey guys, Im taking my 05 sedan to the dealership tomorrow to get it checked up on bc my warranty is up in a few months. I know there is a stock issue with the front struts tending to go bad, and also the device in the gas tank has had some issues actually showing the right amount in the dash gas meter. Other than those two things, any suggestions on other things (Recalls/TSBs) that can be fixed under warranty at the dealership?
Old Dec 16, 2008 | 01:31 PM
miltoda's Avatar
do you have the common sedan 'rocking seat' syndrome. Basically, does your drivers seat seam loose and rocks back and forth a bit when you push against the steering wheel? Mine does that, gonna get it fix soon next time i'm at the dealership.
Old Dec 16, 2008 | 10:57 PM
fbpem1's Avatar
tsb's has to be a failed part, just becuase it might go bad its not going to get fixed. just a heads up on that.
Old Dec 16, 2008 | 11:18 PM
miltoda's Avatar
'True, but i was just giving him a heads up to something that he might have thought was ok, but actually has been identified as a problem.
Old Dec 16, 2008 | 11:20 PM
stats's Avatar
yea i dont have the rocking seat luckily, but from what i have heard the other two problems get replaced under warranty... wonder if i can convince them to put a coupe suspension in instead...
Old Jan 12, 2009 | 07:59 PM
Rallycraft's Avatar
The struts are only going to get replaced if they are leaking, or otherwise obvious failure. If they are not and do get replaced your tech is scrounging around for hours and will fabricate the problem to get past the warranty admin to pick up a few hours. depends on if you get an honest tech or not.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
BradMD_96
Oct 6, 2015 09:31 AM
1Typhoon
Sep 25, 2015 08:45 PM
