TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Help,,car wont start! :/ 2005 G35 coupe
Old Oct 24, 2011 | 02:24 AM
nelbarr's Avatar
Exclamation Help,,car wont start! :/ 2005 G35 coupe
Hi everyone, I am new to this forum and just encountered a problem with my 05 g35 coupe, manual transmission. I decided to change the spark plugs and before i started I followed a DIY spark plug threads and I went ahead and removed the battery cables negative and positive first then went ahead and removed the bolts to get to the spark plugs. I finished putting in the spark plugs and all bolts and went ahead and plugged the battery terminals but my car wont start now! :/ my battery is good because the radio, interior lights work fine, can anyone please help me out? I would really appreciate this so much, thanks.
Old Feb 23, 2013 | 08:52 PM
Shakuya88's Avatar
Does the engine crank but doesn't start? Also does it sounds like it tries to fire at all? May not be related at all, but on my 04 I was doing something else (still had to move all those wires) and I ended up breaking the ground wire for the ignition coils. It's a small wire with a 10mm bolt on the front timing chain case. I've seen others break there before too if wires get moved frequently.
Just saw the date of OP....lol
Blakelyg35
Aug 15, 2015 12:12 PM
kenthung
Jul 21, 2015 05:56 AM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
quickspeed6
24
Jul 15, 2015 11:06 AM
