TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
door lock problem
Old Jun 18, 2012 | 08:59 PM
kartkid's Avatar
door lock problem
Is there a TSB for the door locking failure as it seems to be a common problem??
Old Jun 19, 2012 | 06:12 PM
pythonjosh's Avatar
Not that I know of, there should be. All years of coupe are effected.
Old Jun 25, 2012 | 12:44 AM
guitarrocker98's Avatar
I just went in and put a new door lock I had to take out the window and everything PITA!!! Now that I have done it I could easily do it again. If you need any advice on doing it you can PM me. I did not want to do the 5$ fix.
Old Jun 25, 2012 | 12:39 PM
pythonjosh's Avatar
Please create a new thread. Even I have been wanting to know this procedure.
I've looked at the OEM actuator hundreds of times, and every time I don't see an easy way to do it!
Old Jun 25, 2012 | 04:54 PM
K I will try and do it, but I don't have any pics so it will have to be a step by step.
Old Jul 6, 2012 | 12:40 PM
DailyRunner's Avatar
Have you created it?
Hi,
Have you created the thread yet for this? I need to do mine.
Thanks!
Old Jul 6, 2012 | 05:12 PM
SukaZenki's Avatar
Is it because the $5- Fix is too technical to do?
Or is it because in the back of your mind when it's covered up you feel that your G
has been cheapened by a $5 Universal Actuator that does the same thing as $$$$ plus
part from the dealer..LoL
Old Jul 7, 2012 | 10:20 AM
kartkid's Avatar
what and how is the cheap fix done??
Old Jul 11, 2012 | 02:09 AM
Nope I just didnt feel like doing the $5 fix. I didnt feel like drilling a hole in my door, and I found a decent deal on a actuator. I have not created a thread as I have been working 50+ hours a week and I own my on company so it takes its tole. I will get to it eventually. Its really not that bad. Just the window is a pain.
mike730
Jan 12, 2018 04:25 PM
xluke
Jul 30, 2016 01:48 PM
skippyG
Jan 25, 2016 01:18 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
