TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Help! Whistling sound from engine (?) when going over 35
Old Jan 31, 2013 | 09:10 AM
Firamaster's Avatar
I have a '04 G35, and anytime I go above 35mph I get this weird low pitched whistling sound from the front of the car. Sounds like its coming from the engine block. This has be going on for about 2 months, and I'm trying to fix it now. Any Ideas or help?
Old Jan 31, 2013 | 04:57 PM
dukehotty's Avatar
Is your car completely stock? No pop chargers or super chargers?
Old Feb 1, 2013 | 11:41 AM
Firamaster's Avatar
It has an upgraded intake, not sure what brand. I also have Brembo brakes if that's important to know.
Old Feb 1, 2013 | 01:01 PM
dukehotty's Avatar
Your intake might be the whistle but that is something you would have noticed as soon as it's put in. You should try and post a video clip of the sound. I'm sure someone on here will be able to answer your question.
Old Feb 1, 2013 | 01:03 PM
350Zed's Avatar
Post pics of the intake.
Old Jul 19, 2013 | 01:16 PM
hdmark's Avatar
if you still have this issue.. check to make sure all of the intake piping is tight. mine was a little loose when i installed it and i had a whistle
Old Jul 19, 2013 | 01:42 PM
guitarrocker98's Avatar
Deck for legit whistles glued under your car. I use to pull this prank in high school. Glue whistles under their car. When they hit 35-45 enough air is pushed through it to make it sound..... So yea check for that. If not that intake is most likely the culperate.
Old Jul 19, 2013 | 02:09 PM
hdmark's Avatar
that ... is... genius... and i'll be doing that very soon to my friends mustang
Old Jul 19, 2013 | 05:07 PM
You can always do it in the exhaust as well. Lets say I was the class clown....... Lots and lots of pranks. We also soaped aka drew with dove soap on a girls car for 14 days straight every night. Only the windows. Annoying part is the soap suds up soooooooo bad. We also got her tires just off the ground put it on blocks she got in the car the next day tried to go and could not..... That one is harder and more dangerous. More can go wrong but the whistle one is a good one.
Old Jul 31, 2013 | 11:50 PM
chris_sims1981's Avatar
Check the rubber moulding on the front edge of the hood
TWASkyliner
Feb 8, 2020 08:00 PM
tiguy99
Mar 1, 2016 11:42 AM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
derres
Aug 28, 2015 03:27 PM
ghost_g35
Aug 7, 2015 10:31 AM
