TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Car running poor! Help!!
Old Oct 26, 2015 | 03:30 PM
Dubsakk666's Avatar
I've had my 03 coupe 6mt for about 3 years now, and the only problem I ever had were some bad 0 2 sensors, I would change the air filters, oil and filter etc, even the spark plugs.
About a year ago my car started to run real poor, it idled high, it would stall, and consume so much gas.
I've tried everything, I've changed the spark plugs, I'd clean the maf sensor, throttle position sensor and it would not fix the issue, but it would get alil better when I clean the intake system. I believe this issue started after I changed the o 2 sensors a year ago, could it be?? In cold starts, it would surge almost like there is too much gas in the motor on start up, so the car would choke up alittle and it has a random misfire too... Last codes I got was, idle was too high, and another one that said, running rich I believe, I've tried it all, have you had this problem? I've done the relearn process, all of them and nothing seems to work. Help please!! I also noticed my air suction isn't as loud as it used to be:/
Old Dec 9, 2015 | 07:02 AM
telcoman's Avatar
Veteran: Army
Ever think of following the troubleshooting steps in the FSM?
Telcoman
Old Dec 9, 2015 | 10:04 AM
VenomGT9's Avatar
Bad fuel? kink in the fuel line or maybe a bad injector?
Possible vacuum leak maybe around the plenum after the spark plug change.
Old Dec 9, 2015 | 10:41 AM
hurleyguys's Avatar
Telcoman
dude you remind me of the state farm commercial when aaron rodgers asks the fan if that is all he says.
but on topic. it sounds like an air leak. make sure all your connections are tight and there are no holes or disconnected hoses.
Thebaws11
Jul 2, 2021 11:36 AM
joeslates
Sep 11, 2015 11:19 PM
Chadwick Arnold
Sep 9, 2015 02:59 PM
Julianpnce
Sep 8, 2015 04:40 AM
