TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Overheating issue, weird.....
Old Jan 31, 2018 | 06:48 PM
Joshua1739's Avatar
I've been running without a thermostat for about 5 months everything is working fine, heater all good. I put in a new thermostat two different times now and when I put it car overheats and hearer blows cold. Anybody had issue before?
Old Jan 31, 2018 | 07:06 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Never run WITHOUT the thermostat >.<
You are having issues with a new thermostat because you aren't properly bleeding air from the system, google up how to "burp" a G35, it's a fairly complex process, if you break the plastic purge valve on the heater core line you can order up a metal replacement one (or just plan on replacing it because it's a MUCH better part anyways and only $25) from Z1 Motorsports.
Air gets trapped behind the thermostat and needs to be purged or the thermostat doesn't open and it starts to overheat, not having the thermostat means no air gets trapped behind however you have MUCH longer initial heat times (excess bearing wear due to slop expansion tolerances for a longer duration on every cold start)...
The whole point of the thermostat is to trap heat INTO the engine so it gets up to temp quicker, not to cool the engine when it's hot.
lemmy999
Mar 9, 2018 08:03 AM
mtdurham
Apr 11, 2017 12:21 AM
cochinogato
Nov 3, 2011 03:08 AM
SE2002
Jul 10, 2008 10:59 AM
brycea
12
Dec 10, 2007 11:05 PM
