TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
back window rattle
Old Feb 4, 2006 | 12:10 AM
jcarlson9's Avatar
back window rattle
has anyone experienced a back window rattle or buzzing ? not the big back window,the small side one.
Old Feb 10, 2006 | 02:34 AM
RitzBiz's Avatar
i've noticed a rattleing comming from that direction...... but hadn't had a chance to check it out yet. Mine's an 06 model, what year is yours?
Old Mar 7, 2006 | 10:30 PM
VadorG356MT's Avatar
Back Side window noise
Yes, I have the same problem. Took it into Lokey Infiniti they service tech could not hear any noise. Picked it up put in first gear window made popping noise. Rolled 10 ft first speed bump...heard the noise. Turned right ( heard it) turned left (heard it) pulled out of the dealer...heard it. I guess the service tech has bad hearing. If it cont I will take it back on my next and last oil change. I'll document it again then if one day it cracks the dealer will pay.
On another note where can I find info on the run-flat indicator coming on on long trips???
Old Aug 17, 2006 | 08:02 PM
jimpier's Avatar
Back window rattle
Yes, I have that too. Wasn't sure it was the window or the plastic wall back there. I will point out that it could be the window to the dealer. They claim ignorance on all these rattles and couldn't find any on their own.
Old Mar 6, 2007 | 02:08 PM
tubbyg35's Avatar
i had the same problem on my 04 sedan the back windows would make a clicking noise or rattle it would stop if i rolled down the window then up final it got worse so i took it to the dealer and told them and they told me it was a recall and they will fix it i asked the tec what did they do to make it stop they told me the took of the door panel and change the bolts that hold the window regulator and it stop i had it fixed at KINGS INFINTI BROOKLYN NY
leo38cheng
Nov 12, 2015 06:49 PM
ev_g35
Interior
Aug 14, 2015 02:05 PM
kinetek
Aug 3, 2015 04:25 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
