TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Light in Glove BoX!!
Old Mar 30, 2006 | 04:21 PM
TURBOTOM's Avatar
a.k.a kleicoupe
Originally Posted by kidtronix
Perfect solution if you never want to be able to see anything in the dark. Whatever floats your boat I guess.
You dont really need this light during the day, and at night you can just turn on the overhead light, but i only really keep my insurance and registration in there so i dont use it too often.
Old Mar 30, 2006 | 05:15 PM
g35sammy's Avatar
g's suck. go evo ix !!~ hahaha jk~ i miss my G -.- i was posting for a friend who just bought one!
Old Feb 1, 2007 | 08:53 AM
tjm's Avatar
tjm
this is totally not normal, and infiniti knows about it. read my other post here...https://g35driver.com/forums/tsb-technical-bulletins/135886-glove-box-gap.html
then take your cars back to the dealer so they can fix it
Old Feb 1, 2007 | 09:12 AM
kidtronix's Avatar
Optional
Thanks for the update on this! I havent thought to revisit this issue since I a little after I purchased my coupe
Old Feb 1, 2007 | 09:24 AM
macr6's Avatar
Originally Posted by LjN_728
I believe a lot of G's from 03-06' have this problem. I looked around the glove box and never found a pressure switch or anything. I'm assuming it was meant to be this way.
So do the 07's
Old Feb 1, 2007 | 09:40 AM
Msedanman's Avatar
O.F. Administrator
SOLUTION:
It IS normal. Buy some self-adhering foam weather stripping tape that you'd use on your storm door at home. Choose a density that you believe will be sufficient to better seal the opening and cut to size (there are dozens of thicknesses).
I had to do this for my glove box because my seat is all the way back and the light peeks from inside just enough to annoy me. A 0.50"x0.50" foam piece the length of the width of the glovebox solved the problem in 30 seconds. Peel of the backing and stick it in place...and it looks factory, and its graphite colored too so it seamlessly blends in
Where's the ingenuity in this forum?! Hit Home Depot or Lowe's and fix it!
+1...Normal.
No more glove box switch...the light comes on and stays on as long as the headlight switch is turned on to parking or headlights.
You'll have to seal the door better or just take the light out.
C.
Old Feb 1, 2007 | 11:36 AM
GreenGoblin's Avatar
The goblin resurrection
I never noticed on mine but im not gonna look cause then it will bug me like it bugging you guys
Old Feb 1, 2007 | 11:40 AM
HenryLee's Avatar
yea its normal.
I bought sticky tape velcro in black
and taped the soft side of the tape
on the inside of my glove box door.
worked perfect for me.
Old Feb 1, 2007 | 11:54 AM
EndlessWaltz112's Avatar
i never noticed this. ill check this out later today after i get from school.
Old Feb 1, 2007 | 02:08 PM
raff's Avatar
Originally Posted by g35sammy
everyone i just got g35coupe, 06 model. the light in the glovebox is always on even after i close it, i can see the light through the crack, anyone else have this problem? is there a TSB on this? thanks !
i used a very thin foam tape to seal it and it looks good.
Old Feb 1, 2007 | 02:16 PM
CtK's Avatar
CtK
hmmm is this only for the 06 cause i never noticed it in my 04 G
Old Feb 1, 2007 | 03:01 PM
mephistomyhero's Avatar
All Model years have this issue. Also, bringing up this thread for over 11 months ago huh?
Old Feb 1, 2007 | 03:21 PM
AAClaire420's Avatar
Yes there is a TSB on this
I have the same problem, but i dont wanna risk the dealership screwing up my car anymore then they already have, so I think I will just deal with it for now
They are just supposed to tighten the latch on it or whateverz I guess
Old Feb 1, 2007 | 03:30 PM
Well, if there is a TSB on this, I wonder what they are going to do. Unless there is a switch or button somewhere, tightening the latch will only mask the light.
Old Feb 1, 2007 | 03:40 PM
  #30
yeah i know i dont get it lol
