TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
grinding noise in 1st gear
Old Apr 27, 2006 | 12:30 AM
uhohitzmikeo's Avatar
i have an 06MT that is brand new with 500 something miles on it. when i start the car and put it in 1st gear and drive off i hear a grinding noise for about a second then it disappears. It happens everytime after i start the car and drive off in 1st. any idea?
Old Apr 27, 2006 | 11:16 AM
denverb's Avatar
I have the same thing
Old Apr 27, 2006 | 01:20 PM
al503's Avatar
is it a grinding noise or is it like a chatter/cement mixer sound?
Old Apr 27, 2006 | 01:28 PM
its more of like a grinding noise that lasts for about 1 sec
Old Apr 27, 2006 | 01:30 PM
does it happen all the time pretty much and how many miles you have on the car? do you remember running over anything? i think i did and ripped part of the black plastic thingy but i dont think this is the cause.
Old Apr 27, 2006 | 02:14 PM
denverb's Avatar
I have 700 miles now and it was like that from the moment I drove it away I thought it was normal on the MT. The dealer didnt seem to be worried.
Old Apr 27, 2006 | 11:11 PM
i mean we still have warranty...........hahahaha if anything happens
Old Apr 28, 2006 | 06:00 AM
Alan's Avatar
throw out bearing. its "normal".
Old May 1, 2006 | 06:10 AM
Fassster10's Avatar
i have the same thing and i have an automatic...the dealer said it could not find anything wrong with it, but i have noticed it happens more often if i let the car warm up first, i dont know it sounds weird like something grinds on something...my noise comes from the front driver side like the by the tire. where do your noise come from?
Old May 2, 2006 | 02:04 PM
its kind of hard to tell. i know its in the front somewhere under the engine.
Old May 5, 2006 | 06:05 AM
namrock's Avatar
yea i have the same problem too. Ussualy when i don't let the car warm up and take off in 1st gear sounds like sorta a grinding noise...sorta like a wet fart? My moms honda crv does the same thing so i figured it was normal. But i don't know i could be wrong.
Old May 9, 2006 | 10:11 AM
Nyaka VT's Avatar
I have the same problem here, 06 6MT sedan. If I start the car up and move in 1st, as soon as I hit 1700-1800 rpm I hear a short grinding noise for about a second. I am going to take it to the dealer to see what's up, I'll keep you guys posted.
Old May 9, 2006 | 12:16 PM
trey.hutcheson's Avatar
This is the abs system initializing. It's normal.
Old May 10, 2006 | 12:49 PM
Nyaka VT's Avatar
Yep, confirmed with the dealer today it's the ABS self test. Too bad they don't mention it out the door.
Old May 24, 2006 | 03:50 PM
VIP-STATUS's Avatar
From what i know on the 350Z which is the same thing pretty much is that that Grinding sound is not normal. My Friend actually went to the dealer, it was a recall. According to him it is The Rear axel bearings re-packed. You guys might wanna check into that and see.
