so pissed.got dynoed today
Old Jun 25, 2006 | 10:45 AM
  #31
Earl's Avatar
Originally Posted by diablo1356
how is it possible that im only putting down 215 hp and 215 tq max!!!!!....look at my sig...is that ****ing possible??...it was like 95 outside and we did two runs...second run i picked up one hp...it was on a dynojet..im really confused??..and the dyno said that i wasnt running lean or rich..i was fine with the a/f..and to top things off...a 350z ate me on the way back...cant believe this ****..i wanted to stop with the power but now i gotto buy more stuff!..anyone have suggestions as to why my power is so low and what i need to do?
Real low numbers for any A/T coupe. Your combination of mods may be working against each other.
1) stock air box w/k&n & Z-tube = proven mod
2) motordyne 5/16 = proven mod w/k&n & Z-tube
3) custom dual exhaust w/ dual magnaflow mufflers = possible loss?
4) topspeed headers = possible loss?
5) gordgee's 10 wire kit = proven mod (for most)
6) hi intake air temps = proven loss
7) hi coolant temps = proven loss
8) A/F should be lean with mods 3) & 4) - redyno for second opinion on A/F
9) TechnoSquare reflash ++
Old Jun 25, 2006 | 04:08 PM
  #32
trey.hutcheson's Avatar
I love how every one is telling this guy to get a reflash, or change airboxes, or whatever, when we have no other point of reference for this dyno.
Old Jun 25, 2006 | 05:36 PM
  #33
BoostedIS300's Avatar
wtf is a technosquare reflash?
Old Jun 25, 2006 | 05:47 PM
  #34
diablo1356's Avatar
but how is it possible that headers and a dual exhaust could cause a loss??...if anything wouldnt they just show no gain?..and as far as the A/F i felt the same way..that i should be running lean but he ran it twice and both times it was the same..im thinking bout HFC so when i put those on ill probably need a tune..
Old Jun 25, 2006 | 05:53 PM
  #35
jonnylaw's Avatar
Why not try another dyno at another spot if you have the money and see if your numbers are still low before you start changing your setup to be sure?
Old Jun 25, 2006 | 05:55 PM
  #36
diablo1356's Avatar
cause down here in south ****ing texas we only have one that i know of...
Old Jun 26, 2006 | 03:08 AM
  #37
Aldweik's Avatar
Your problem is understanding how the ECU works and the Dynojet numbers seem accurate to me for the weather conditions that you described. Without getting too technical (in layman's terms), The stock ECU has several fuel & timing maps and selects the one that it sees most appropriate for your application and realtime conditions. Higher temperatures, lower octane and non-aggresive driving habits lead to the more conservative maps being selected to avoid knock or conserve fuel. Higher octane fuels have a higher resistance to preignition. Breather mods usually throw off the parameters that the ECU wants to see from the sensors monitoring your engine conditions. If your ECU doesn't like the voltages it sees, it will select conservative maps to preserve your engine. In a nutshell, you need a piggy-back and a good tune to extract power out of almost any bolt on mod.
Old Jun 26, 2006 | 03:35 AM
  #38
gfolo19's Avatar
3rd is t best gear and pullls the hardest for some reason on all nissan 6 speeds the 4,5,6 gears are more cruisin on highway and lack the real punch if that doesnt work...start in 4th get up to 5 or 6 wat ever you have and down shift into 4 youll blow right past the govenor, ooo yea ONE HUGE THING!!! If you didnt have your seat belt on the car is governed thres a wiring harness under the driver seat that severly cuts the power if u dont have your seat belt on idk why nissan does that
Old Jun 26, 2006 | 04:11 AM
  #39
space108th's Avatar
i dont mean to steal ur thread but i have been looking around and cant find it, i was wondering what the "gordgee's 10 wire kit" actually is/does, because i have been reading about it but dont know what it is or does for the car, if anyone can explain or just message me about it so i dont take thread space that would be extremely helpfull, ty adhead of time, take care all
Old Jun 26, 2006 | 01:18 PM
  #40
lightforce18's Avatar
i got 234 stock on my 5at off a mustang dyno.
Something is wrong with ur car and the mods.
Old Jul 28, 2006 | 05:40 PM
  #42
whyjay91's Avatar
Originally Posted by andycon
"ooo yea ONE HUGE THING!!! If you didnt have your seat belt on the car is governed thres a wiring harness under the driver seat that severly cuts the power if u dont have your seat belt on idk why nissan does that".....
!!!! not calling BS or anything...but, can anyone confirm this?
I'll go try it out on my way to the gym and let you know... Will post in an hour or so.
Old Jul 28, 2006 | 06:24 PM
  #43
99atlantic's Avatar
BS.
Old Jul 28, 2006 | 06:48 PM
  #44
driguez's Avatar
please do so......
Old Jul 28, 2006 | 09:01 PM
  #45
ChazM's Avatar
Mustang dyno and Dyno Jet are two different types of dyno's, you can't compare them.
And the seatbelt thing is BS!
