Tailpipe readings for A/F?
Old Apr 21, 2007 | 03:52 PM
JABG35x2's Avatar
Went to get my first dyno pull on the G today, but software/hardware screw-up and after two hours of messing with the computer set up could only get a reading at 1/2 RPMs so gave up. But he had to use a tailpipe sniffer to try for the A/F readings, as when he looked at the setup under the car said he couldn't get to a spot to get a secure weld to put a bung in ahead of the CAT's. My question is: will this give an accurate enough reading of A/F? He wasn't familiar at all with the G--is there any way to get a good A/F reading further up the exhaust chain?
Was planning to send off the ECU to TechnoSquare next week along with the A/F readings. Can they do a good enough reflash w/o the readings, or should I hang back till I can get them to them?
Old Apr 21, 2007 | 09:03 PM
sloppymax's Avatar
the reading from the tailpipe is almost always leaner then upstream before the cat. did the operator mention if he kept losing tach signal?
Old Apr 21, 2007 | 11:53 PM
OCG35's Avatar
When TS does the flash with ECU in the car Tadashi hooks up sniffer to tailpipe, runs cable to laptop in car and takes it for a test drive... I'm not sure how they determine when it's a sent ECU - I think they just go by the mods you list and download a preset program that works for those mods.
Also, I was told that dyno A/F reading are often different from what will show while driving - not sure why... I've had dyno with slightly lean readings went to TS, they did their thing (they way I mentioned above) and it was pretty much spot-on 13 the whole time...
Not sure if this helps you at all... you can always Tadashi (or Yoshi) directly at Technosquare and they can answer your question: (310) 787-0847
Old Apr 22, 2007 | 11:22 AM
JABG35x2's Avatar
Wasn't so much a problem of loosing the tach signal, as it was his hand held unit (controller?) was getting a different reading than the computer, so he figured he had a firmware problem with the connection 'tween the two.
Marlin84
Apr 1, 2020 12:52 PM
KallDay86
Jan 8, 2016 12:42 AM
AL8782
Oct 3, 2015 10:26 AM
NyCrAzY
Oct 1, 2015 09:19 AM
Learned Hand
Oct 1, 2015 09:02 AM
