Quote:
yup that sure is good point that you pointing out, i was too lazy to do dyno.....doh!Originally Posted by raff
Certain mods may give a little loss on the low end but you gain on the top end of your RPM range. That is why you may think you feel a "loss of power" because technically down low you may have lost some. only way to tell for sure would have been to do a before/after dyno.
I did a UNICHIP from an APS kit, you can still tune it on N/A tho japtrix was kinda mad at me lol.
I really wish I did the utec tho =(
If you ever THINK you MIGHT go F/I... get a utec now.
in my opinion what you're feeling is the loss of low end power common with exhaust mods. i basically have the same set up as you...intake, spacer, headers, and i had hfc with the stock exhaust. i have no power loss at all..just a monster after 3000 rpm...try taking your test pipes off and putting the stock cats on...if that resolves the issue than ditch the test pipes and get some hfc...some backpressure is better for torque.
1) your a/f is probably skewered from all those breathing mods
2) topspeed pro-1 is a 3'' exhaust piping - you'll have VERY noticeable down-low torque loss, with moderate up-top gains as a result.
I'll give it a try! thanks!Originally Posted by Jtrain
I did a UNICHIP from an APS kit, you can still tune it on N/A tho japtrix was kinda mad at me lol.I really wish I did the utec tho =(
Quote:
i see, i'll give it a try as well, thanks for help!Originally Posted by diablo1356
Quote:
will a worn out clutch effect the situation that I'm experiencing?
please help! any suggestions would be helpful!!!
I would bet it's the headers. Those headers are more hp than anything, I would have went with the DC sports design for an NA engine. Strup is similar design to Alphawerks IIRC. Something like the DC sports and/or Top speed will give you more torque.Originally Posted by G-Ride Canada
Have any of you feeling less torque or hp producing out of your car after some mods? I have 15/6 MD iso Spacer, strup headers and test pipes, stock Y pipe and Top Speed Pro 1 exhaust. or I might have a leak somewhere again...??? will a worn out clutch effect the situation that I'm experiencing?
I had varis duct, JWT pop, Kinetix intake, crank pulley, top speed headers, injen exhaust and AMA flash. Yes the car lost torque. It gained peak hp. I went from 240rwhp to 255rwhp. My buddies that had the strups dyoned around 262hp with less mods than me. But yes, their torque was not as high. Don't remember the actual numbers.
Quote:
thanks for your advice
That's why you reflash after you have done a significant amount of mods.Originally Posted by G-Ride Canada
I'm not sure if I'm gonna go FI, but don't i need to get my ecu reflashed everytime i put on new mods?thanks for your advice
If you decide to get it flashed with Technosquare, and happen to add a new mod, then you have a choice to get it reflashed which will only cost you $150. That's their reflash discount for past costumers.
In my opinion, its not worth spending up to $1,000 on UTEC.
If you're staying NA, a reflash should do just well.
I agree, well as some said earlier, pretty much all my exhaust system are a disappointment that need to be fixed or swap, will they still be a problem after the reflash? thanks for you timeOriginally Posted by skaterbasist
That's why you reflash after you have done a significant amount of mods.If you decide to get it flashed with Technosquare, and happen to add a new mod, then you have a choice to get it reflashed which will only cost you $150. That's their reflash discount for past costumers.
^^^ You are correct!Originally Posted by 2EFNFAST
1) your a/f is probably skewered from all those breathing mods2) topspeed pro-1 is a 3'' exhaust piping - you'll have VERY noticeable down-low torque loss, with moderate up-top gains as a result.
That size is for FI applications, which needs little or no backpressure.
NA needs backpressure to keep the torque. Max dia for NA should be no more than 2.5".
Thats the reason right there his butt dyno feels less power, he has a lot less backpressure=a lot less torque.
Doubt if a tune will bring back the torque. Lack of backpressure is the main issue here, imo.
My G35 > Your Life
where did you get the topspeed exhaust from.
I want one but cant find them anywhere
Wanna sell yours??? lol
Quote:
Not sure if Topspeed really is 3" piping, but if it is, then that definately isnt beneficial on a NA car.Originally Posted by G-Ride Canada
A reflash will always help no matter what; but you might see better gains if you had a 2.5 or 2.25" exhaust.
Let's just say that I'm going to swap to HKS hi-power, and have done the ECU reflash, do I still need to worry about changing HFC for more back pressure?Originally Posted by skaterbasist
Not sure if Topspeed really is 3" piping, but if it is, then that definately isnt beneficial on a NA car.A reflash will always help no matter what; but you might see better gains if you had a 2.5 or 2.25" exhaust.
thanks bud
Quote:
thanks bud
HFC always helps.Originally Posted by G-Ride Canada
Let's just say that I'm going to swap to HKS hi-power, and have done the ECU reflash, do I still need to worry about changing HFC for more back pressure?thanks bud
From what I hear, HFC will make you feel more power and torque in the mid powerband.
If you want more info, im sure you can PM "OCG35" for more help; he has alot of bolt-on's including HFC, and had his ecu reflashed by Technosquare.
you are probably running lean and pulling timing so the car feels like a slug. More than likely if you add fuel you will feel more trq.
When I got HFC I could not believe how limp the car was (search my thread for Crawford HFC)... I went to TS and Tadashi did some tests, I was running pretty lean - he added fuel... after a couple of test drives & tweaking the a/f ratio the car was right at 13 relatively consistently... I immediately notice more trq!
I have CAI, 1/2" spacer, HFC, catback exhaust... when you add that many breathing mods you need to add fuel. This is why so many people think certain mods don’t work. They slap something on without tune and expect amazing results.
OP, get your ECU reflashed and you will be fine.
