UTEC....Worth it
Old May 21, 2007 | 07:19 AM
KPierson's Avatar
Originally Posted by skaterbasist
Just to point something out, that's never a good thing. Raising it by, say 500 rpms as an ECU reflash might do makes sense. But removing... possibly R.I.P engine for those who don't control the revs as easy as some do.
Anyhow, as it already has been stated, UTEC is worth it if you plan on going FI in the future. As for me, Ill be getting an ECU Reflash (TS) as soon as I have enough bolt-ons.
But I also plan on getting a UTEC in the future, as I will be going FI after graduation college.
Sorry, that was supposed to say 'raise' not 'remove'. The UTEC manual is very specific about the care that must be used when setting the rev limiter.
Old May 21, 2007 | 02:27 PM
cc1012's Avatar
why does everyone love the utec? I had one on my wrx and then got rid of it cause it was such a piece of $hit and got a ecutek reflash and will never put another piggyback comp on my car again. But have they made some serious upgrades to it? because when ever the weather changed my car ran like garbage. I also paid to have it tuned by 2 diff tuners.
Old May 21, 2007 | 02:42 PM
KPierson's Avatar
Its not perfect by any means, but it is fairly cheap ($900) and has the ability to drive the coils/injectors by itself. The OEM MAF hits 5V at ~5000 RPM on 8psi. This makes it impossible for any reflash or other 'piggyback' to tune the car with the MAF. The UTEC, to my knowledge, is the cheapest tuning tool that will do this.
Old May 21, 2007 | 02:44 PM
cc1012's Avatar
^^^ this is tru...... But if you got the cake to drop on a TT how do you not come up with the money for a hydra or AEM standalone. None the less why wouldnt you so you could get rid of the MAF
Old May 21, 2007 | 02:58 PM
KPierson's Avatar
Its all about goals. Why spend another $2K on something I don't need?
To me, if I can't tune it myself, I don't want it, period. I had a Unichip in my car for a year and it was miserable. No one within 5 hours of me could tune the thing, I was stuck with my tune.
With my UTEC I can adjust my temp compensation tables if the temp changes and my car starts running bad. If I run lean (or rich) anywhere in the map I can add fuel. Not only did I save $1-2000 over a full standalone, I am also saving money on tuning, and more importantly time on getting the thing tuned by someone else.
Old May 21, 2007 | 05:46 PM
cc1012's Avatar
like i said i know what the utec does, ive had it and used it.......... I was just wondering if they made any improvements with it? I Think that the when the cobb software comes out it will be a better option. The stock reflash is always a little smoother then the piggyback unit. Its really the set it and forget it option.
Old May 21, 2007 | 06:03 PM
ttrank's Avatar
Grocery getter
I would not mess with the UTEC until you go FI. Then it is by far the best in its price range. The HKS (and maybe soon AEM) will be better options but are also 3X+ the price!
Old May 21, 2007 | 06:05 PM
Jeff92se's Avatar
Red Card Crew
Man I wish there was an engine management comparison thread.
What is so bad about the EU? It features fuel and ign (advance and retard).
Old May 21, 2007 | 06:06 PM
KPierson's Avatar
The OEM reflash is worthless with any real form of FI, as the MAF sensor is maxed out too soon. To my knowledge, no one has remapped a larger MAF sensor to the OEM ECU.
Old May 21, 2007 | 06:19 PM
KPierson's Avatar
I honestly don't know much about the EU. What is its resoluton? Price wise it is very comprable to the UTEC, but the UTEC is plug and play, and doesn't require a million other pieces to make it work.
Old May 21, 2007 | 06:45 PM
ttrank's Avatar
Grocery getter
Me either, nor would it be worth it. MAP is the way to go for boost!
Old May 21, 2007 | 06:50 PM
Jeff92se's Avatar
Red Card Crew
http://www.titanmotorsports.com/greul.html
Seems to have some nice features. They modified the fuel adjustments so it's not a modified maf signal (that could affect timing). Also ign is directly changed.
But I'm by no means an expert and I would really like to hear your opinions.
You are right about the harness thing. It seems a car specific harness is necessary to get it "plug and play".
Old May 21, 2007 | 07:07 PM
KPierson's Avatar
I just talked to a buddy that has the EU (he is wanting to buy a UTEC) and he said that the EU has a resolution of 500 RPM. The UTEC has a 250 RPM resolution.
The EU is capable of driving the injectors and coils directly - I didn't know that.
Old May 21, 2007 | 07:08 PM
Jeff92se's Avatar
Red Card Crew
I was thinking how important that resolution diff is for us NA guys. I'm sure the boosted guys need to get all the resolution you can get.
Old May 21, 2007 | 08:51 PM
  #30
trey.hutcheson's Avatar
Jeff, check out this thread over on my350z about the EU: http://www.my350z.com/forum/showthread.php?t=224832
