Dynoed my car today @ DynaPack 3000. PIC inside
Old May 30, 2007 | 03:57 AM
GTT's Avatar
GTT
G35 Twin Turbo
Hello guys,
I went to a shop today to tune and dyno my car. eventhough my car is pulling harder, but it was making 230whp and 168wtq. I'm really confused, i thought the different between the dynapack 3000 and dynojet is not hat big in numbers. My car was making 273whp & 235wtq.
Old May 30, 2007 | 04:03 AM
Skaterbasist's Avatar
Retired SuperMod
So let me get this straight:
273whp & 235wtq was on a dynojet
230whp and 168wtq was on a dynapack?
Very strange. Although comparing different dyno's even from the same type is "wrong", you should still see higher numbers on a dynopack.
I myself made 265 whp & 245 whp on a dynapack. I would ask the shop.
It would also help if you showed us the graph.
Old May 30, 2007 | 06:21 AM
aleok's Avatar
that looks dangerous...
Old May 30, 2007 | 07:59 AM
GTT's Avatar
GTT
G35 Twin Turbo
I forgot to get the graph from the shop, but i will give them a call tomorrow.
Old May 30, 2007 | 08:18 AM
izmir41500's Avatar
G35driver Addict
it's not. the dyno is attached to the wheel hub, the jacks aren't holding up the car.
i'd like the see the graph.
Old May 30, 2007 | 06:27 PM
GTT's Avatar
GTT
G35 Twin Turbo
Here is the graph i thought it was 168tq but it's 217 " still bad"
Old May 30, 2007 | 06:50 PM
Retired SuperMod
This dyno is useless unless you have some sort of baseline dyno to show how much you gained over stock.
Some dynojets/dynapacks might be calibrated differently than others, so its essential for you to dyno in the same place.
Do you have a stock dyno? Nevermind these numbers, they can be deceiving. 232 whp & 217 wtq "sounds" really low for your mods, but that's not really the issue.
Remember, the purpose of a dyno is for tuning purposes, so seeing these numbers without a stock baseline is senseless.
Old May 30, 2007 | 06:53 PM
Retired SuperMod
Also, I would present this "issue" with the coordinator of the dyno shop; you made 40 more whp on a dynojet. That sounds very strange.
Old May 30, 2007 | 09:17 PM
GTT's Avatar
GTT
G35 Twin Turbo
I was making 250 whp and 227wtq on dynojet without the Utec, so making 27whp on dyno jet after the utec is correct for me ... don't you think
Old May 30, 2007 | 10:19 PM
Retired SuperMod
That's not my point.
My point is, a Dynapack usually reads significantly higher than a dynojet. But that doesnt seem to be the case here; its actually completely reversed in your case, which I find strange.
Like I said before, the dyno's are a bit useless without a stock baseline. I think you should have either stuck with the dynojet or the dynapack, because these two types of dynos are not comparable with each other.
Old Jun 7, 2007 | 10:52 PM
GTT's Avatar
GTT
G35 Twin Turbo
Thanks for the info
chinee
Jun 10, 2024 07:48 PM
ClwMike
Jul 23, 2015 12:55 PM
sick_sixspeed
Tuner & Dyno
Jul 21, 2015 03:23 AM
