ECU ????? please chime in!!
Old Jun 16, 2007 | 03:40 PM
1illgt350's Avatar
i have been having ecu problems for a while and i have a question i am currently going to oreder a new ecu but it is from a 04 6mt and i have a 03 6mt, the 04 work for my application?
Old Jun 18, 2007 | 11:09 AM
_jb's Avatar
_jb
Photographer
What makes you think you're having ECU problems?
Why would you order an ECU for the wrong year?
Old Jul 14, 2007 | 03:13 PM
dTor's Avatar
I've read (either here or on my350z) that ecus, even if they are for the same year and application, have different part numbers that reflect changes/updates made to it.
Only get the same part # ecu that your vehicle currently has, unless there are people who can confirm that different part #s will work with your application.
Old Jul 14, 2007 | 03:52 PM
fortified's Avatar
As mentioned on the Orisis topic, you normally have to contact a dealer (should not matter which one) and give them your VIN. They will then be able to tell you which ECU P/N to use for your G (as it came equipped from the factory).
I guess there is a way to get it from the ECU itself by opening it up. Nothing I would mess with unless you are sure it is bad.
Old Jul 14, 2007 | 05:46 PM
ttrank's Avatar
Grocery getter
How do you know the ECU is the problem?
06g35
Feb 14, 2022 05:59 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
MThawkins86
Oct 24, 2015 02:07 AM
DRG35R
Sep 16, 2015 05:33 AM
G35VSHNG37
Sep 10, 2015 01:54 PM
