Initial utec install
Old Aug 31, 2007 | 06:02 PM
805g's Avatar
So, i plug it onto my ecu. I connect the tuner reg from turbo xs in line with my computer.
utec-->tuner-->computer.
Is this correct?
Also, do i start my car before or after loading a map.
does anyone have a map that might help match my set-up?
fast intentions exhaust, ur pulley set, MD 5/16 spacer, injen cai.
Lemmmmme know i am quite a noob when it comes to my utec.
is there anything that would absolutely **** up my car that i should know when it comes to the utec?
Thanks all...
Old Sep 1, 2007 | 01:12 AM
805g's Avatar
want to do this manana.....bump!
Old Sep 1, 2007 | 03:04 AM
_jb's Avatar
_jb
Photographer
I'd suggest taking the UTEC to a Tuner and let them install it.
Old Sep 1, 2007 | 02:30 PM
805g's Avatar
boooooooooooooooooooo jb boooooooooooooo
Old Sep 4, 2007 | 07:58 PM
Sinister350GT's Avatar
I just went through this.
UTEC is connected to the ECU
Tuner is connected to the UTEC VIA Serial cable
you connect to both units VIA the phone cord thing on the side of the Tuner.
now if you know how to connect to the Tuner or Utec VIA hyperterminal
get connected and down load the Intake Exhaust maps from TurboXS
You need the MAP and the Parameters file.
Once in the screen for the Utec at the bottom it will give you options to get around.
Hit CTRL+U to upload a txt file from your comp.
on the menu for hyperterminal go to transfer/send TXT file.
Find you map and hit open.
It should say that it is processing the map.
do the same for the paramteres file.
that should be all you need.
I got all this info from TurboXS two days ago when they walked me though my setup.
I am currently rinning the UTEC and the TUner.
Old Sep 5, 2007 | 02:39 PM
GreenGoblin's Avatar
The goblin resurrection
Where was the cheapest place u guys found the utec I've seen like 700 shipped the lowest any one can beat that or is that bottom dollar
Old Sep 6, 2007 | 11:26 PM
805g's Avatar
how do i go about installing the o2 sensor? does it need to be welded? any links to diy's?
Thanks all
R350k5
Oct 1, 2015 08:41 PM
gatorglaze
Sep 10, 2015 12:03 PM
Machine Head
Sep 4, 2015 07:22 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
EliteG
Engine - Electrical
Aug 5, 2015 07:50 PM
