Disturbing dyno
Old Dec 10, 2007 | 07:47 PM
O HELLA OEM's Avatar
damn only 220hp thats odd
Old Dec 10, 2007 | 07:50 PM
G-Ride Canada's Avatar
well doesn't the ECU need time to adjust with the plenum? as well as other mods? I say get that ECU reflashed when you are done with modding, and dyno'd it up, maybe with a tune as well?
Skaterbasist's Avatar
Retired SuperMod
That's low for a dynojet. But unless you have a stock (or previous) baseline dyno from the exact same dyno, those numbers are completely meaningless.
Old Dec 10, 2007 | 07:58 PM
lekker_droom's Avatar
I know, I know. Unfortunately I never got a baseline stock dyno. I'm resetting the ECU now.
I have the battery unplugged and stepped on the brake. This iswhat Tony at Motordyne just suggested. He said just unhook the Negative terminal and step on the brakes and that's enough to reset the ECU.
Old Dec 10, 2007 | 09:13 PM
just step on the brakes? for how long? first time heard this method of resetting... anyone?
Old Dec 10, 2007 | 11:50 PM
OCG35's Avatar
what gear did they dyno in?
Old Dec 10, 2007 | 11:59 PM
3rd and 4th. Both were identicle.
Is there any merit to the idea that the MREV2 needed to get broken in or rather that the car needed to "learn" a little?
The MREV2 was installed and the car was moved literally 10 ft over the the dyno bay. Maybe I should have done the dyno a few days later? I dunno.
Old Dec 11, 2007 | 12:08 AM
c.breeze_gt's Avatar
Lisa Fleming=HOT!!!
i had the same disappointment from my dyno also...try getting a exhaust next, it might free up the "rear" a little bit. i was dynoing a mere 228whp on a dyno dynamics with 1/2" spacer, mrev2, z-tube/k&n filter. when i got my exhaust and hfc's, i jumped up to about 252whp.
Old Dec 11, 2007 | 01:40 PM
Hydrazine's Avatar
In cases like this it can be due to the ECU not being in performance mode.
I've seen people dyno like that at dyno days, get totally bummed out, reset the ECU, redyno at the end of the day and their final numbers come out just like everyone elses.
Old Dec 11, 2007 | 01:43 PM
617G's Avatar
CFW (Carbon Fiber Whore)
Originally Posted by Tperk96
Thanks again! I have now lost faith in the dyno system :-)
dynos are used to tune and measure gains, not cack size
without a baseline with the same dyno, the numbers the OP posted are meaningless
Old Dec 11, 2007 | 01:44 PM
617G's Avatar
That's pretty damn good for a DD
Old Dec 11, 2007 | 01:51 PM
Hexxum001's Avatar
Great! We have the exact car, and I was hoping for 300hp to the wheels with bolt-ons. That dream is now crushed, silly me for being optimistic!
Getting to 300whp with just bolt ons is going to be very difficult. I don't think I have heard of or seen a G with just bolt ons hitting 300whp. Good luck.
Old Dec 11, 2007 | 02:02 PM
Gilley's Avatar
^ +1 You have to rebuild the motor and add a bunch of parts. It's cheaper to just go FI.
Why did they only dyno in 3rd and 4th gears on a 6MT? 5th gear is 1:1 drive ratio.
Old Dec 11, 2007 | 03:07 PM
Hey Tony, I was the one who called you yesterday. I'm not gonna worry about it. I reset the ECU like you suggested last night. Unplugged the Neg terminal stepped on the brakes and just left it unplugged for about an hour.
Old Dec 12, 2007 | 12:56 PM
  #30
g35ctuner's Avatar
jeeez, thats alot of work. why didnt you just got to autozone and have them hook up the scan tool for free, and you have them clear the codes. yes, even if you dont have any codes in memory if will erase all the learned values and start all over fresh. the new values will take into consideration the new air flow rate with your new mods. i did a md 1/2 spacer 2 weeks ago and i took it out as soon as i installed it and it ran like pooo! did a ecu reset and within 20 miles or so i could really feel my new power!
