Dyno Day in Arizona? - Custom Tune by Church Auto with OSIRIS!!!
#31
#32
#33
#35
Hey guys, for the 2003 owners, we need to confirm that your ECUs are not first generation. First generation ECUs are not reflashable. You can check by looking under the glove box on the passenger side footwell. You will have to remove the panel (it just snaps out) and look up at the ECU connector. Flashable ECUs use a black snap on connector with two main plugs. I'll try and post a picture up, but you can also see what they look like at turboxs' site
http://www.turboxs.com/more_info.php?ID=217
You can also go to the download section of their site and download the 350Z files and look at the install PDF. It shows a variety of pictures of the ECU.
If you have any other questions, feel free to call me at 310-713-6171.
SC
SC
#36
#39
#42
I called Xact Dyno, and it looks like it will be $600 for the facility on Saturday. They are usually closed on Saturday, but will open up shop for us. I would have to make sure everyone is confirmed to do this, and that we would have to add on an additional $150 each. So for each of us, the tune would be $600 + $150 Dyno Shop Time = $750
Please let me know if everyone is ok with that.
ALSO, let me know if you guys want to layout a timeline of who will be there when. Thanks for everyone's help with this!
#43
Looks like a newer ECU. If you like, with the battery disconnected, you can unplug the ECU harness (you have to pull the clip out on one end and then swing it down) and see if it matches up with the picture links I posted. Just keep in mind the car may idle funny for a few minutes after you plug it back in and start it up.
SC
SC
#44
