Motordyne 5/16'' spacer and MREV2 dyno test
Old Feb 21, 2008 | 11:24 AM
Texasscout's Avatar
Yes the MREV2 fits all cars, but it will only WORK with a REVUP model. In fact the manifold starts as an 04 model and then MD mods it. If you have a REVUP you CAN use just an 04' lower plenum and get some gains, but not as much as the modified plenum will give you.
At least, that's MY understanding.
EDIT: I stand corrected, from MD website:
Originally Posted by MotorDyne Engineering
MREV 2 Manifold:
The Motordyne MREV 2 Manifold is high-torque plenum mod designed for use on any VQ engine.
When used with a 5/16" spacer on the REVUP engine, every test to date shows MREV 2 Manifold will add a "minimum" of 15+ HP and 18+ TQ at 4500 RPM. MREV 2 Manifold is easily the single most effective bolt on modification available for the REVUP VQ engine.
When used with on the non-REVUP engine, the gains are very similar to that of the 5/16" spacer but the MREV 2 Manifold will show a slightly lower peak value, with a slightly higher average value and a slightly higher TQ value. Overall, MREV 2 Manifold provides "area under the curve" and is the highest gain plenum mod available
Old Feb 21, 2008 | 10:01 PM
amoreno35's Avatar
Thanks Guys.
Old Feb 22, 2008 | 09:28 AM
spddmn124's Avatar
do you have the air/fuel map??? if you can can you post them??
Old Feb 27, 2008 | 01:14 AM
Red_G35's Avatar
butt dyno- can you feel 10whp?
I'm going to install the spacer this week, curious if I should be excited to feel any difference?
Old Feb 27, 2008 | 10:12 AM
Texasscout's Avatar
I put MREV2 on mine and yes you can!
Old Feb 29, 2008 | 03:13 PM
Modified Dave's Avatar
Nice thing about the MotorDyne stuff is that they provided a ton of midrange torque and this is the type of power you feel most with the butt dyno, because it produces much quicker throttle response at the speeds we generally cruise around at on the streets.
a/f maps - I'm actually sending all the data from the dyno to Tony at MotorDyne so he can do a full analysis for us. I'll post up his report once I've had a chance to get him the data and he's had a chance to analyze it for us.
Old Mar 1, 2008 | 11:14 AM
GTreeFive's Avatar
MODified..
Is this instead of doing the APS Tall boy mod?
Old Mar 1, 2008 | 07:18 PM
Texasscout's Avatar
Yes...
Old Mar 27, 2008 | 02:58 PM
BlueDevilBAMF's Avatar
Based upon the description from Motordyne quoted above it seems that for the cost, it might not really be worth doing MREV 2 on a non Revup VQ such as my own. They seem to say that while I will gain some area under the curve, the gains above and beyond what I already see from my spacer won't be much.
Old Mar 27, 2008 | 07:19 PM
OCG35's Avatar
very true... cost/benefit isn’t great... but when you've picked all the low hanging fruit, it is an option for a bit more power…
Old Mar 27, 2008 | 07:31 PM
I'd rather put my money towards my Osiris tune...
Old Mar 27, 2008 | 07:33 PM
MikeYo's Avatar
im doing these mods next
Old Mar 27, 2008 | 07:34 PM
Skaterbasist's Avatar
Retired SuperMod
Excellent review Dave. The MREV2 just keeps on proving itself test after test. The spacer is also very consistent, though the curve of the MREV2 is much more under the midrange powercurve.
It seems to be true that with the MREV2, you will lose a bit in the top end. But the spacer itself "cancels" out any of the loss of top-end power from the MREV2.
I hope im not asking for too much, but can you post a graph of your stock baseline with the latest dyno you have? (Stock vs Intake, Exhaust, Spacer, MREV2).
Thanks Dave
PS. Got any AFR graphs?
Old Mar 27, 2008 | 08:51 PM
OCG35's Avatar
a tune is part of the low hanging fruit... I'm talking about when you have done all the basic stuff (and a tune is part of the basics)... then a modified lower collector is a nominal purchase for slightly more performance...
You know the routine... there is never an end... I'm now planning torque converter and valve body (2-3K) - and cams & headers (4K+ with install)...
So my only point was that before you get costly items it is something to consider. Most certainly not before all the easy stuff/typical stuff.
Old Mar 27, 2008 | 09:07 PM
  #30
donot521's Avatar
I have a 2005 G35 coupe 5AT with sport package
so am I a Rev-up or non-rev up?
