Motordyne 5/16'' spacer and MREV2 dyno test
Old Mar 27, 2008 | 09:39 PM
  #31
Skaterbasist's Avatar
Retired SuperMod
Originally Posted by donot521
I have a 2005 G35 coupe 5AT with sport package
so am I a Rev-up or non-rev up?
No automatics have ever been revup. Only 05-07 G35 Coupe 6MT's & 05-06 G35 Sedan 6MT's have the revup engine.
Old Mar 27, 2008 | 11:40 PM
  #32
nikkaitsme's Avatar
can't wait to do this mod next
Old Mar 28, 2008 | 12:32 AM
  #33
Hydrazine's Avatar
Originally Posted by BlueDevilBAMF
Based upon the description from Motordyne quoted above it seems that for the cost, it might not really be worth doing MREV 2 on a non Revup VQ such as my own. They seem to say that while I will gain some area under the curve, the gains above and beyond what I already see from my spacer won't be much.
Correct.
The generally only recommed doing both on a non-revup engine is if:
1) Your A/F ratio is good. (If this is good it will make about 4-6 more HP in the midrange.)
2) You are either a hard core racer or a dyno junkie.
OTOH if you have a REVUP engine, its just the opposite, I almost always recommend doing both.
Old Apr 7, 2008 | 12:37 AM
  #34
Retired SuperMod
Since Dave's graphs were all the exact same scale, I was able to accurately photoshop his baseline with this latest graph..
Stock vs Exhaust, intake, spacer, MREV2
Old Apr 7, 2008 | 01:13 AM
  #35
Hydrazine's Avatar
Good job with the photoshop Henry!
That plot shows some great gains and area under the curve.
Old Apr 14, 2008 | 04:52 PM
  #36
Lolly Baggins's Avatar
I know what I need to get next now. Lol.
Old Apr 14, 2008 | 04:56 PM
  #37
Quick question, is this the 5/16" kit you purchased?
http://www.g35parts.com/9083/osc/pro...roducts_id=319
Old Apr 18, 2008 | 03:13 PM
  #38
Paniller's Avatar
It seems like much of that was from the exhaust. What do you mean by "exhaust?" Did you do headers, test pipes, cat back?
NVM, I trolled around and found another thread of yours with dyno. The results seem consistent with what I saw above.
The graph below is the Stillen full cat-back on my '06 G35 6MT vs the OE cat-back.
Old Aug 20, 2009 | 04:35 PM
  #39
haagen_dazs's Avatar
i am new to this..
does the plenum spacer change the sound of the engine/exhaust too?
Old Aug 20, 2009 | 04:46 PM
  #40
Modified Dave's Avatar
Lolly Baggins, yup that's the one I'm running.
Paniller, for this test we only installed a catback exhaust. I have, however, subsequently installed headers and high-flow cats, but those came a few months after we did the intake mods including the MotorDyne stuff and the Stillen intake and catback true dual exhaust.
haagen_daz, I never drove the car with just the MotorDyne mods since we tested some other parts on the dyno that same day, but given that the plenum spacer does increase the overall volume of the plenum it might deepen the sound of the intake charge a bit by virtue of changing the resonance or harmonics of the overall intake tract and the plenum/manifold itself. Tony from MotorDyne can tell you more about sound if you shoot him an e-mail.
Old Aug 20, 2009 | 05:35 PM
  #41
Hydrazine's Avatar
Originally Posted by haagen_dazs
i am new to this..
On your engine, the 5/16" spacer will change the induction sound modestly. You have to listen for it to hear it.
On a REVUP engine the MREV2/spacer combo will change the engine sound substantially. Its louder, deeper and easily noticed.
Old Aug 20, 2009 | 06:17 PM
  #42
OCG35's Avatar
on my car (non revup) with 1/2" spacer the engine is notably throatier.
Old Feb 15, 2011 | 10:45 PM
  #43
cmesidewayz's Avatar
Correct me on this.. I have an 05 6MT.
so the MREV2's are made from an 04 lower plenum, and the top of each intake is shaved down to give better flow...
wouldnt adding a spacer to a revup engine give similar clearance over the top of each induction tube(or whatever the correct name is) so it would be pretty similar to having a revup with the MREv2 lower plenum and no spacer ?
but you get better overall gains by having even more clearance with both ?
Old Feb 15, 2011 | 11:08 PM
  #44
sillyoldtayo's Avatar
The MREV2 also has different length intake runners (induction tubes haha) than the revup models lower plenum has. For some reason adding a spacer on the revup engine does nothing. The spacer only benefits an MREV plenum or a non revup plenum. Theres quite a few threads and a dyno chart here and there that show what the spacer does on a revup...
See this link
https://g35driver.com/forums/engine-...um-spacer.html
Old Feb 16, 2011 | 01:23 AM
  #45
msommers's Avatar
Seems intuitive but I'm guessing the spacer and lower plenum will help with airflow on FI applications as well?
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
SIKKI
Steering & Suspension
Sep 16, 2015 01:14 AM
Terry_G35
Sep 10, 2015 08:17 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
