UpRev and osiris
-2006 IP GT350-
on
Originally Posted by kuwait_G35
thnx guys ...
first .. can i do it myself ?????
second .. how many HP i will get from the reflash ???
![Big Grin](https://g35driver.com/forums/images/smilies/biggrin.gif)
Originally Posted by Skaterbasist
If you really want to understand all the features and benefits on the Osiris, plus some insight on future abilities, read through all the 50 pages on the Z forum
: http://www.my350z.com/forum/showthread.php?t=279548
on
Hi, I am thinking of getting the osirius myself but I have the 03 coupe and I want to be able to check the AFR (worry it might be running a bit lean). Does that mean I have to get a wideband o2 sensor? If so what is the best way to do this that won't cost too much? Or should I be considering something else?
(ztube, stillen box, 5/16 spacer, engine damper)
Thank you
Thank you
Originally Posted by nismog35driver
Hi, I am thinking of getting the osirius myself but I have the 03 coupe and I want to be able to check the AFR. Does that mean I have to get a wideband o2 sensor? If so what is the best way to do this that won't cost too much?
Thank you
Thank you
Yes, you need a wideband O2 sensor. A popular one is the Innovate Wideband. It is several hundred dollars. There may be other options but I'm not sure what they are.
on
Does it get hooked up to the ecu or to the osiris? I am a bit confused here since I am not sure if I just need the sensor or all the other stuff as well (total novice here). Should I just get this:
http://cgi.ebay.com/ebaymotors/Parts...m300235216331&
Thank you!
Thank you!
on
http://cgi.ebay.com/ebaymotors/Parts...0023521 6331&
Thank you!
Thank you!
