08 Sport Sedan. Coolant leak above AC Compressor
Old Dec 30, 2023 | 08:59 PM
vestaviascott's Avatar
G35 Sport Sedan Manual 6 Speed
Coolant is leaking from just above the AC Compressor on the side of the engine. Best I can tell. It drips from a single bolt. Tightened the bolt but no joy Put a paper towel up between the AC compressor and the engine block (Above the bolt) and it gets soaked with coolant when the radiator cap is loosened. Any ideas? There's no way to see exactly where its coming from but appears to be just above that bolt and between the engine block and the AC compressor.
Old Jun 23, 2024 | 07:43 PM
Kevy's Avatar
Infinity g35 2003 sedan
Same dammed problem
I got the exact same problem
Did you loosen the bolts of the ac compressor mounting bracket?
InfinitiGdxb
Jul 23, 2020 10:33 PM
ginyama
12
May 29, 2019 09:01 PM
EK1067
Nov 2, 2015 02:09 PM
hotdamn
Oct 7, 2010 11:17 AM
imalazeeass
Jul 15, 2005 09:19 AM
