finally tuned 2003 G35 coupe
Old Aug 4, 2008 | 11:55 PM
Skaterbasist's Avatar
Retired SuperMod
Originally Posted by SDGeneralCounsel
actually these aren't great numbers for a built NA motor....
Completely disagree. 282 RWHP/260 TQ on a dyno dynamics is definately 300+ rwhp & 280+ tq on most other dynos.
How is that not great from an NA VQ35?
Originally Posted by seung012
hmmm, definitly over 10K.... I know it is a lot but I'm koo with it.
A few questions:
- Is the "over 10k" price tag including full bolt-ons or just the engine internals + labor?
- Can you give us a full list of the modifications your car has including the internals?
- Why did they only rev the engine to 6300 RPM on a built cammed engine? The power was still climbing and looks like it has more to give.
Old Aug 4, 2008 | 11:58 PM
BlueDevilBAMF's Avatar
Originally Posted by Skaterbasist
Also, why is there a power dip at 5300 RPM? Clutch slipping?
Isn't that when VTEC kicks in, yo?
Old Aug 5, 2008 | 12:06 AM
seung012's Avatar
With all boltons and labor I'm looking at around 14K+.... I got a few sponsorships here and there for parts. Here is the list of what I have so far.
Wiseco Pistons 96mm/11. 0 : 1 Pistons
Eagle/SCAT H Beam Rods
ARP Rod Bolts
Block inspected and cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Rotating assembly balanced
Crank magnafluxed and the journals micro-polished
New Moly coated Race Spec main bearings installed
New Moly coated Race Spec rod bearings installed
Block assembled
New OEM Head Gaskets
Heads inspected and cleaned
Heads redecked
Ported exhaust and intake runners
Oil Pump - VQ35 RevUp
JWT S2 Cams
JWT Heavy Duty Valve Springs
5 angle radius cut valve job
New OEM Valve stem seals installed
Valve Stem Heights set
Cold Clearance set for stock cams
Heads assembled
New OEM Rev-up Oil Pump
ARP VQ35 Head and Main Stud Kit
Z-tube
JWT popcharger
Copper iso thermal spacer
Strup Headers
Strup Testpipes
Fast Intentions exhaust w/custom x-pipe
Unorthodox Pulley Kit
ACT HD clutch and pro lite flywheel
UTEC
As far as the 6500, I have to get the ecu reflashed to set the rev-limit higher...I'm wanting to set it at 7300 and shift at 7000K. Surprised you caught that Skate.
Old Aug 5, 2008 | 12:08 AM
seung012's Avatar
Anyone know a cheap place to get reflashed? The UTEC can't change the rev-limit.
Old Aug 5, 2008 | 12:18 AM
Retired SuperMod
The Technosquare L-Spec flash should get the job done:
- 7100 Rev Limiter (500rpm Increase on Non-Revup)
- Speed Limiter Removal
- Drive By Wire Re-mapping
I'm sure you can make peak power around atleast 6800 RPM on an NA VQ35 built motor. The car has more to give!
Old Aug 5, 2008 | 12:21 AM
seung012's Avatar
where can I get this? definitly want every amount I can squeeze out.
Old Aug 5, 2008 | 12:54 AM
I don't like AAM for builds, but I'm sure they would be willing to negotiate a price to do the reflash to remove your rev and speed limiters. They use the same software as Technosquare and you wouldn't have to ship your ECU to CA.
Old Aug 5, 2008 | 06:20 AM
seung012's Avatar
hmmm... so just drive up there and get it done huh?... wonder how much.... heard they over charge a lot.
Old Aug 5, 2008 | 06:26 AM
snavematt's Avatar
just a sedan
tell them your with NGC or PM Dave@altetered on here
Old Aug 5, 2008 | 07:09 AM
kennyb's Avatar
Congrats Champ on the nice motor. And don't worry about the money spent, we all have to treat ourself to something these days besides you earned it my friend. I wonder how your old exhaust I still have, would sound like on that motor....
Old Aug 5, 2008 | 11:03 AM
trey.hutcheson's Avatar
There are three engine builds over on my350z that may interest you:
Jeremy Tibbs(Audible Mayhem of Performance Factory): http://my350z.com/forum/na-builds/25...r-project.html
Adam at z1: http://my350z.com/forum/na-builds/28...soup-nuts.html
And rednezz. See here: http://my350z.com/forum/na-builds/29...ilt-motor.html
And here: http://my350z.com/forum/na-builds/31...-294-rwhp.html
Also, if you really want to get your hands dirty with the utec, you can actually raise the rev limiter. Be sure to read the manual several times. Page 32 begins with a section named Open Loop Fuelling. Here's an excerpt(read the entire manual to make sure you really "get it", and consult with your tuner):
Open Loop Fuelling turns UTEC open loop fuel control on or off. When Open Loop
Fuelling is enabled, the UTEC uses its own background fuel table to determine injector ontime
instead of the factory ECU’s fuel table once the car is past the Open Loop Threshold
parameter setting. This allows the UTEC to drive the injectors completely independent
from the factory ECU. This mode is active when the Open Loop Fuelling value is set to “1”.
Enabling OPEN LOOP FUELLING is recommended for more complex level of modifications
such as forced induction and is REQUIRED if would like to use Rev Limiter parameter to
increase the rev limit.
Disabling OPEN LOOP FUELLING is recommended for less modified cars. Fuel tuning is
done piggyback-style by offsetting the MAF voltage seen by the factory ECU. This mode is
active when the Open Loop Fuelling value is set to “0”. NOTE: When Open Loop
Fuelling is disabled all other Open Loop Fuelling Parameters will have no effect.
Old Aug 5, 2008 | 11:13 AM
Audible Mayhem's Avatar
please take it to a dynojet before claiming what it would make on one
good to see more NA builds, we have one coming up here soon that should turn some heads....
Old Aug 5, 2008 | 02:27 PM
Klubbheads's Avatar
Im jealous. Great Job. ~300whp and keeping the weight down is a very significant gain. I won't be surprised if u hit 12s in right conditions. The car must be a blast to drive.
BTW how was the car tuned?
Old Aug 5, 2008 | 03:56 PM
seung012's Avatar
didn't know this would offend anyone.....if a tuner who has worked on both is telling me this, then I believe him.
Old Aug 5, 2008 | 03:58 PM
  #30
seung012's Avatar
The car was tuned with a UTEC on the dyno dynamics in 95 degress heat while running for more then 2 hours.... then we went on the street and did some more stuff on the laptop.
