Motordyne plenum spacer installed
Old Feb 9, 2009 | 02:08 PM
SilentAttack's Avatar
So I installed the spacer yesterday and everything runs great. My only question is I squeezed a small piece of rubber between the upper plenum and spacer (rubber that goes under the oil cap) which I dont think woud affect anything but I hear a small hissing noise when I accelerate. I figured the hissing noise was just the air intake sucking in more air now that there is more space in the plenum. Is my assumption right?
Old Feb 9, 2009 | 02:16 PM
Chamoru671's Avatar
make sure that the rubber pice that gose around the oil cap is not Pinch between the upper and lower plenum when you install the spacer, thats where your hissing is coming from.
Old Feb 9, 2009 | 02:18 PM
Heist.'s Avatar
yes probably just more air.... but you really should pull the rubber out from in between the spacer. You are leaking air by doing this and you have a chance of rubber going in your manifold now. It really should not take you more then 10 minutes to loosen the bolts and take it out.
Old Feb 9, 2009 | 10:48 PM
I guess I will take the time to take it out.
Old Feb 9, 2009 | 10:52 PM
twin001's Avatar
You NEED to get that out of there. That's air that's getting into your engine and not going through your MAF. I'm surprised your car is not running like crap....or is it?
Old Feb 9, 2009 | 10:59 PM
elayman's Avatar
Leak!
Old Feb 10, 2009 | 01:30 AM
site4soreice's Avatar
i just recently bought motordyne spacers havent installed yet., whats the pros and cons? any noticable difference, power and sound.
Old Feb 10, 2009 | 05:07 AM
RickyGill's Avatar
there aren't really any cons. but you will notice a difference in power and sound. just make sure you install it properly and its better to have someone help you out.
Old Apr 23, 2009 | 04:10 PM
MikeGrote's Avatar
OMG +1. probably running fairly lean which is not good, not to mention that air is getting into your engine unfiltered! "i suppose ill take the time to fix it" is the incorrect resposnse. the correct response is "ok, i will do that before i drive the car anymore so i dont do any perm damage to my engine, if i havent already"
CoupeObsession
Aug 17, 2015 01:05 PM
Raven7
Aug 14, 2015 04:40 PM
IkonG35
Aug 10, 2015 09:33 AM
deathsupport
Canada
Aug 2, 2015 10:13 AM
