how to change maps using CC? Osiris
Old Feb 17, 2009 | 05:20 PM
4drmadness's Avatar
Hey guys how do u exactly switch the maps with osiris? I know its from The cruise control, but what buttons do you exactly press. thanks
Old Feb 17, 2009 | 05:31 PM
twin001's Avatar
EDIT: I had to go outside and remember how to do it!
You hold down the Accel/Decel switch, then...while holding it down...you press "Cancel" the number of times the map you want to select. For example, if your 91 Octane Performance map is #4 then you would hold down the Accel/Decel switch and, while holding it down, you press cancel four times. Your cruise light will then blink that number of times.
Old Feb 17, 2009 | 05:39 PM
4drmadness's Avatar
hmm so holding down cancel, and clicking the decel button however many times. thanks
Old Feb 17, 2009 | 05:47 PM
twin001's Avatar
No, hold down the Accel/Decel switch (top switch, right hand) then click "Cancel" the number of times as the map # you want to switch to....then release the Accel/Decel switch.
Old Feb 17, 2009 | 05:55 PM
Skaterbasist's Avatar
Retired SuperMod
1+
And make sure you hold the Accel/Decel switch almost a second before you hit the cancel button or else it might not want to switch maps.
4drmadness's Avatar
alrite. cool
Old Feb 17, 2009 | 06:09 PM
4drmadness's Avatar
hmmm it worked, lol. another question. so for e.g, if i am in my 4th map, and i want to go back to the 1st map, do i have to jus click the cancel button twice?
Old Feb 17, 2009 | 06:14 PM
twin001's Avatar
No, click it once. Again, look at your dash lights. The green cruise light will blink the same number of times as the map you are currently running.
Old Feb 17, 2009 | 06:15 PM
4drmadness's Avatar
oh thts good, so the green light gives a confirmation of which map you are running by blinking that many times.
Old Feb 17, 2009 | 06:20 PM
twin001's Avatar
Right!
Old Feb 17, 2009 | 08:33 PM
OCG35's Avatar
why didnt your tuner go over this with you???
Old Feb 17, 2009 | 09:13 PM
4drmadness's Avatar
he did go over this with me, but i was too excited to drive my car, and forgot all about the Instructions
Old Feb 17, 2009 | 11:05 PM
twin001's Avatar
easy to do....just make sure when you go FI that you listen to EVERYTHING your tuner/installer has to tell you.
Old Feb 17, 2009 | 11:13 PM
lekker_droom's Avatar
LOL. I was the same way except I didn't forget how to switch it.
Old Feb 17, 2009 | 11:17 PM
4drmadness's Avatar
will do
