OSIRIS Final Numbers, HB SPEED,SOCAL
#62
#63
do you know if the tuner paid attention to trying to make power after 6500 ? I saw similar gains on my tune but i feel as if my intake screams really loud but the car really doesnt go as well as i would wish passed 6500... i normally shift around 6400 even after the tune because i just feel as if the power falls off more... i got to post my chart but i know my fall off is worse than yours.. my numbers are in my sig on a dynojet.. but with no headers
#64
their plug is not compatible with your car - and apparently they haven’t felt there is enough demand to make an alternative.
It’s too bad, because DaveO was ready to do an article about their product - but couldn’t even get it on his early model doggie door.
As for other tuning options - Technosquare is a great alternative.
#65
#67
you are correct, I did not have a sedan but i had a early early 03, the car itself was made in 02 and mine couldn't be tune either, but of course Sam@GTM still did a tune for it no problem, yank the whole damn ecu out and do it, what do they mean they cant do it Ain't hard. He used Uprev/gtm custom tune on my car before he did the tune with the vpro also.
Damnn Why not?? I know you can't plug it into the obdII but you could still go around that and tune it, suxs for that guy tho.
#68
We however have more capable software and 4 Pro Tuners in the greater LA area, so if it is a late 03 Sedan then he can bring it to any of our Pro Tuners, or he can order Osiris Standard from them/us also.
#69
Rev-up motors come with better piston/rods and can handle more peak RPM, though I wouldn't stray too far above the stock redline even in them with the stock internals.
#70
For revups, a tuner can play around with exhaust timing and squeeze a little more out of it, making the powerband a little more flatter than a stock revup. (Non revups already have a bigger power drop-off after peak power than revups do).
Sadly, an HR/VHR wipes us off the floor when it comes to power past 6300 RPMS (typical peak power for a DE).
#71
So depending on the valvebody and what specs you decide on, it can be a huge benefit over stock.
#72
Untrue. If it is an early 03 Sedan with the older ECU then technosquare does not work on it either. Flat out it is different architecture and cannot use the same flash technique.
#73
The problem with the DE non rev-up motors is the pistons. You can change out parts and help it make power in higher revs, but you will significantly shorten the life of the motor. The shallow ring lands, high cylinder temps, and extremely high piston speeds in the DE motor do not lend it to high RPM use.
The DE rod bolts are the weakest link... using rev-up rod bolts, rev-up oil pump and after market valve springs I have been running 7500 rev limit.
#74
I'm sure people have had rod bolts fail or valve springs etc. But if you leave the stock emissions pistons in the motor and expect the motor to last with high RPM use (not just daily driving) the pistons will come apart. Add forced induction and make things even worse.
#75
Extended use at high RPM we always see the pistons fail. 4 motors in customers cars in the last year. Always against our suggestion of leaving the stock RPM limit in place on that motor.
FI with stock internals at high boost is always a bad idea and not really what we are talking about here. I suspect the failure you reference is from FI applications and there is probably more to it than high rpm.
