Tuning the Fcon V Pro
Old Jun 7, 2009 | 06:54 PM
tilmonr's Avatar
Hi all, just got one quick question. just got my car back from the shop (don't want to put the shops name in just yet, going to post pics and number in the FI side later on...) and there telling me that i need to get a reflash. now i have the new Fcon out and i was just wondering why i would need a reflash to get the idle set higher than what it's at now. (about 300-400rpm) are then trying to get more money out of me or is that the only way to rest the idle (and also take off the check eng light..). just looking for some input. Thanks.
Old Jun 14, 2009 | 12:46 AM
rcdash's Avatar
That is correct. The FCON does not control drive by wire or creature comforts. The stock ECU controls the throttle (idle, speed limiter, rev limiter on some cars) and of course manages the CEL system. Check out UpRev.com and look up Osiris.
Old Jun 14, 2009 | 09:24 AM
tilmonr's Avatar
yeah I just went ahead and did the reflash. Well my throttle is controled by the blitz throttle control.
Old Jun 15, 2009 | 02:21 PM
UpRev's Avatar
Your throttle is controlled by the factory ECU. The FCON does not control the electronic throttle. The Blitz controller only manipulates the input to the ECU for your throttle peddle not the output to the throttle itself. It is probably safest to remove that part altogether so that your factory ECU is not getting false information, and the piggy back FCON isn't having to manipulate even more random information.
Old Jun 15, 2009 | 02:23 PM
Glex25's Avatar
Administrator
You can raise your idle with a consult II or a cipher by 200RPM more than stock
Old Jun 15, 2009 | 02:57 PM
tilmonr's Avatar
Thanks for the information, got something else to ask. I'm in the military in San Diego and in order to get base stickers they need a smog inspection to see if it passes emissions. I don't need it to register (from a different state..) and was looking at some possibilities to get it to pass that part. any suggestions???
Old Jun 15, 2009 | 03:49 PM
terrycs's Avatar
Assuming you do not have "connections", the best shot of passing short of pulling everything off is to have the cats back in and hot when they do the test. You are SOL if they do a visual check.
Old Jun 15, 2009 | 06:27 PM
tilmonr's Avatar
Yeah I tried going in hot... Didn't work.
Old Jun 16, 2009 | 02:50 PM
_jb's Avatar
_jb
Photographer
Do you have Cats?
Why did you fail?
-jb
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
AJC128
Nov 1, 2015 11:55 AM
