03 G35 sedan ECM reprogram?
Old Sep 15, 2009 | 08:07 PM
pinky1121's Avatar
Hi all, I just got my car back from my mechanic who help me replace my throttle body and after he replace it, my engine light came on. And he was working on it for half a day and told me that I need to take it back to the dealer to get the ECM reprogrammed. Has anybody has this issue before? Can this is done by myself? I just spend about $400 for parts and labor to get this done and I called the dealer and they said it will cost me another $120 to get it reprogrammed. Help any advise will help!! Thanks
Tony
Old Sep 15, 2009 | 08:39 PM
6MTFTW's Avatar
This is straight from the FSM:
"Perform the “Throttle Valve Closed Position Learning” when harness
connector of electric throttle control actuator is disconnected.
Refer to EC-92, "Throttle Valve Closed Position
Learning" .
 Perform the “Idle Air Volume Learning” and “Throttle Valve
Closed Position Learning” when electric throttle control actuator
is replaced. Refer to EC-93, "Idle Air Volume Learning" ."
Old Sep 16, 2009 | 12:35 AM
Tollboothwilley's Avatar
If you do the idle air volume learning procedure and let the car idle for 90 sec or so, you should be good.
Old Sep 16, 2009 | 04:52 PM
pinky1121's Avatar
Thanks, i will give that a try. Doe anybody know where i can find the "idle air volume learning" Thanks again!
Old Sep 16, 2009 | 06:05 PM
just do a search.
Old Sep 17, 2009 | 10:11 AM
ttrank's Avatar
Grocery getter
Moved...
Old Sep 17, 2009 | 10:54 PM
pinky1121's Avatar
hi i try the out the procedures but i still cant get it to work. you have any idea what else i should try. This is very frustrating!
Old Oct 1, 2009 | 07:46 PM
which did you try?
for me after I did the throttle relearn it took almost 90 sec for the idle to drop to where it needs to be
Jusseth
Sep 13, 2020 12:25 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
laksjd84
Jul 24, 2015 05:12 PM
