Only got 260whp and 255tq. Seems a little low to me...
Old Jul 28, 2010 | 06:44 PM
Tollboothwilley's Avatar
Only way to know your true gains is to DYNO before any mods. But all in all, not too bad of numbers.
I'm completely sure that your INJEN is taking away from your power though.
Old Jul 28, 2010 | 06:52 PM
Romanski85's Avatar
what do you recommend as the replacement?
Old Jul 28, 2010 | 08:36 PM
MM_G3520's Avatar
Z-tube with an 05/06 back (bigger velocity stack) and an Amsoil dry filter (K&N's suck, IMO)
Old Jul 28, 2010 | 11:14 PM
Reidonly's Avatar
The "Y" pipe goes into an "X" pipe which goes into a dual 3" exhaust
How is that even possible? An H pipe or X pipe is what you use in a dual exhaust setup. If you have a Y pipe, that means it joins back into one pipe. So how do you have an X pipe after the Y?
Old Jul 29, 2010 | 07:03 AM
Romanski85's Avatar
Here is ur answer Reidonly
http://www.motordyneengineering.com/...b491a5c4fb4ec8
Old Jul 29, 2010 | 07:41 AM
TurTLe*'s Avatar
GRD dyno should read low tho, since its the one where they take off your wheels.
is the price for a flash and dyno tune still $500?
Old Jul 29, 2010 | 08:14 AM
Romanski85's Avatar
Yeah Sloppy said the SAE sheets are normally lower..
I paid $550. Got in at 1:30 and she was done at 4:20
Old Jul 29, 2010 | 11:22 PM
Reidonly's Avatar
Maybe you are seeing something I am not. There is no x-pipe anywhere on that page. All I see is an exhaust that goes into one pipe followed by a 1-in, 2-out muffler/resonator.
Old Jul 29, 2010 | 11:55 PM
doeboy's Avatar
That muffler might act like an x pipe on the inside, thats all that I can think of
Old Jul 30, 2010 | 12:45 AM
Reidonly's Avatar
An x-pipe functions by much more than simply having two different paths merge then go apart again. There is a lot involved in the design of an x-pipe that makes it beneficial.
Old Jul 30, 2010 | 01:27 AM
Jairen's Avatar
Maybe we can get Tony to show us a cutaway of the muffler used in the TDX2.
Old Jul 30, 2010 | 01:31 AM
doeboy's Avatar
i know that, what I was stating is that maybe he thought and was referring to that as an x-pipe cause there is nothing else there that could be an x-pipe
Old Jul 30, 2010 | 08:56 AM
Romanski85's Avatar
The muffed has a built in x-pipe in it. I'm not sure how to explain it really. Tony will have to do that part, lol.
Old Jul 30, 2010 | 11:03 AM
+1, it looks like a square resonator but is actually an X pipe
BTW, stock intake is ok but people that think the stock revup intake is good because of the larger velocity stack but think other aftermarket intakes with much better velocity stack suck....well, it just goes to show you who the lemmings are on this forum.
The problem with most aftermarket intakes is heatsoak. Handle that, and you'll have much better options than the stock intake.
Old Jul 30, 2010 | 08:25 PM
  #30
MM_G3520's Avatar
If there was an aftermarket intake that did not induce noticeable heat soak, and had a good filtering element, I would be on it in a second.
A lot of people just run cone filters that suck in hot air :-/
