Noob s/c tuning questions
Old Jan 9, 2011 | 08:47 PM
ELMACHOGERACHO's Avatar
I finally am breaking down and going for more power. I got to meet the R&D head of stillen this week who single handedly designed the VQ37 S/C kit, and he got me itching for more power.
I tried searching but it was pretty hard to find any specifics on what i am asking about.
First i am going to get DW 600cc inj and im debating between the Warlbo FP and the new DW pump. Im sure the DW pump is over kill but the guy from stillen was raving about DW products.
Second, i already have a boost gauge and im getting a wideband gauge and oil pressure. What type of line are you guys using for your oil pressure? Ive heard horror stories about the nylon line leaking. Did anyone put another T-fitting on the existing T for the feed line for the S/C?
I will either be buying Osiris or using the Osiris that we have been using for the S/C g37 we have if possible. I know a wideband is critical, is a single WB ok or should i get a dual like this? dumb question but this will work to log with osiris, correct? It said in the description that it should.
http://www.injectedperformance.com/h...trollerkit.htm
Where do you mount the wb O2's? I would assume weld on a bung but at the front of the y pipe, but in reading about Osiris, i saw that it is possible to turn off the checking for dtc's (rear O2's) so could i then just install them where the rear o2's are normally mounted?
Old Jan 9, 2011 | 09:12 PM
kartkid's Avatar
Hey You already have dual wide bands stock
Old Jan 9, 2011 | 09:16 PM
ya but you cant tune thru them.
Old Jan 10, 2011 | 07:46 AM
kartkid's Avatar
If you use your up-rev osiris you can as well as a few other systems that can as well use the ob2 port to utilizes them as a wireless gauge (Ipod-Itouch)
Old Jan 10, 2011 | 07:59 AM
from what i have read/asked, the factory wb sensors are not accurate enough to properly tune with.
Old Jan 10, 2011 | 06:48 PM
kartkid's Avatar
Belive me they are fine for that if you watch how quickly they react
during tuning you would see and go check out the ones they use they are Bosch 02 sensors
15667 and seem to be better than most in after-market kits.
Read up on up-rev or contact jared there and get the straight answer.
but by far I have found up-rev great and vince at RTTuning great.
Old Jan 15, 2011 | 01:22 PM
bump for more inputs
jsimonk
Dec 22, 2023 03:49 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
as25656800
Aug 9, 2015 07:25 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
