5AT G w/ Turbonetics, installed and tuned by CIN
Old Jan 24, 2011 | 10:31 AM
GrocryGettr's Avatar
This is a 5AT we recently finished with a Turbonetics kit. Everything else is stock on the vehicle, inluding the midpipe and muffler.
She made 344hp and 394tq with a conservative tune.
The owner already called and asked if we can "detune" it! He says tires are expensive!!!
Old Jan 24, 2011 | 10:35 AM
da mayor's Avatar
looks like a real conservative tune.
Old Jan 24, 2011 | 10:30 PM
bash27jp00's Avatar
Ohio G Club Member
is he happy with the way the automatic shifts?
Old Jan 25, 2011 | 09:04 AM
That is one of the reasons he want's us to put a smaller wastegate spring in. When the car shifts and the rpms drop back to where the engine is making over 390lbs of torque, the tires let loose and his car is not set up to put that much power to the ground.
Remember that in an automatic car, you don't loose near the boost pressure between shifts as in a manual, so the power is always there.
Old Jan 25, 2011 | 10:37 AM
bash27jp00's Avatar
Ohio G Club Member
I was thinking of doing this same set up on my car. Would you recommend this on a daily driver? I didn’t want to set any hp records just wanted a more responsive car that I could still drive daily. I’ve got an 03 slushbox
Old Jan 25, 2011 | 11:27 AM
The Turbonetics kit is decent for the money, but for almost the same amount, you could do a Momentum Performance or STS kit.
Old Apr 27, 2011 | 11:09 PM
r1forever80's Avatar
Is the 5at kit different from the 6mt kit?
Old Jun 1, 2011 | 04:44 PM
taylor@momentum's Avatar
yes, slight differences on the exhaust side pre turbo.
Old Jun 1, 2011 | 05:01 PM
I researched and mostly I believe its the crossover pipe.
Old Jun 1, 2011 | 05:17 PM
Correct.
Old Jun 1, 2011 | 05:23 PM
Thanks for the confirmation. Im on the hunt for a 5at crossover now. I really dont want to cut and reweld the 6mt one i have
SoCalTed
Apr 26, 2004 01:23 AM
MiamiG35sedan
Intake & Exhaust
Apr 4, 2004 09:14 AM
G35Spot
Drivetrain
Jan 18, 2004 10:08 PM
bullseye
Nov 12, 2003 07:22 PM
