400hp g35
Old Apr 5, 2011 | 11:43 PM
the_sedan's Avatar
Originally Posted by HavokGT
you aint getting ****. you wont touch 300hp with all NA mods... FI is the only way to go. do some research. seriously
i disagree. i'll be seeing 300hp shortly NA.
and yeah, you wont ever see 400hp NA...unless you're built and spraying. boost is your best and only bet if you want that much power. gl.
Old Apr 6, 2011 | 12:09 AM
herrschaft's Avatar
I think your best bet would be to get a supercharger, that can get you 400hp at the crank. They're not very expensive and you can probably install it yourself, except the tune. Unless you change the internals, your not going to see much gain while staying N/A.
Old Apr 6, 2011 | 12:22 AM
SDGenius's Avatar
how is 400hp a little more power?
Old Apr 6, 2011 | 12:26 AM
xxxxxxxxxx's Avatar
Originally Posted by Jeff92se
140 hp shot of Nos
:smh: is nitrous, NOS is a brand lol
Old Apr 6, 2011 | 03:09 AM
seymore4's Avatar
m56
Do you have MINIMUM $10,000 to blow?
If not then tap out now please.
Old Apr 6, 2011 | 03:38 AM
prinny's Avatar
Didn't we have someone else post a similar thread like a couple days ago, but it was 350 horsepower instead.. I think this guy is just trolling lolol..
Old Apr 6, 2011 | 10:50 AM
iiiiiekoiiiii's Avatar
damn u just killed someones dreams.
Old Apr 6, 2011 | 01:48 PM
bluedevils95's Avatar
all i have to say is good luck on your research. You want 400HP. FI.
Old Apr 6, 2011 | 07:14 PM
nyqueenz's Avatar
for staters.. you are also gonna need large cams and headwork, fuel return and a good EMS..
http://aamcompetition.com/i-4764630-...11-5-1-na.html
Old Apr 6, 2011 | 09:38 PM
jookyshank's Avatar
I haz hugz to givez
Like you know anything about making real power on a VQ.... Pfffft
Old Apr 6, 2011 | 09:48 PM
HavokGT's Avatar
Your best bet... just make it look nice. Thats why Im doing. Then doing a v8 swap later down the rod... just as good as a built and fi motor..
Old Apr 6, 2011 | 10:32 PM
g-adabout's Avatar
I have near 400whp and it isnt cheap.
Research is the way to go. I did my research and found the best way to go. n/a is fun, but boost is the only way you will reach your goals. Good luck!
Old Apr 11, 2011 | 07:31 PM
Eno's Avatar
Eno
Lightbulb
Originally Posted by Aptos936
Doing FI on the cheap isn't really a good thing.
To build a good 400hp+ motor you really need to plan out the entire build and expect to spend around $25K or more to do it right so it won't blow up when you're trying to impress some hot babe.
+1
I'm in the middle of a TT project right now with intec racing in WA. If everything went perfectly it would have cost me about 15 total including kit, install and a few supporting mods.
Well it didn't go perfectly. 25k is a pretty reasonable number once you start factoring In some of the upgrades (I'm AT and a built tranny is in the plan- that alone is 5k once it's shipped back and forth.) also with a built block we decided to upgrade injectors and fuel pump and really go for it. We're reaching for 500.
Anyway. 400 on these cars is a lot. I would set my sights a bit lower- like... Try to actually get stock numbers. You MIGHT be able to do that with a few simple upgrades. An Osiris tune would tighten things up a bit, plenum spacer, ztube, kn filter, high flow cats and an catback exhaust. The MT boys might want to chime in about some of their particular hardware.
Some guys even swap out with 350z parts. They're a similar platform, as you probably already know.
Already the bolt ons I've mentioned are probably a few grand if purchased all new. Keep your eyes on the marketplace. Loads of deals there.
Old Apr 11, 2011 | 07:33 PM
Eno's Avatar
Eno
He BETTER know how to get some horses out of the VQ
Old Apr 11, 2011 | 07:49 PM
  #30
TurboDreamzG's Avatar
Did he really just say spend 25k to go FI? ..... I think if he just wants your moderate 400HP he wont have to spend anything near that, IMO
