Dyno results: 2005 G35 coupe 6MT (bolt-ons)
A friend of mine has a neighbor who works at a shop that has a Dynojet, so on a whim we decided to head up and do some pulls today. I haven't dyno'd since my last batch of mods, so I finally got to see some new numbers. I'm pretty happy with the results - my butt dyno was saying I should put down about 270/250, and I wasn't too far off. Ended up making 267whp/247tq (SAE). The printer wasn't working at the shop, so I will post up dyno sheets once he emails me the files.
Current mods:
- JWT Popcharger & Z-tube
- Motordyne MREV2 lower plenum & 5/16" spacer
- Kinetix resonated test pipes
- OEM HR y-pipe
- bumped timing 2 degrees
- 267whp/247tq SAE
Pull #1: http://youtu.be/hCkV0k9p6RM
Pull #2: http://youtu.be/cviEPedN1RE
Pull #3: http://youtu.be/BOuj0LJ1Va0
Previous dynos for comparison...
July 2009:
- OEM HR y-pipe
- 250whp/223tq SAE
June 2008:
- 245whp/219tq SAE
Current mods:
- OEM HR y-pipe
- 267whp/247tq SAE
July 2009:
- OEM HR y-pipe
- 250whp/223tq SAE
June 2008:
- 245whp/219tq SAE
Negateeve. I've beaten this thing within an inch of its life on a daily basis for 60K+ miles over the last 3-1/2 years and it hasn't blown up yet. Lean is mean lmao.
There's a lot of talk about air mods tricking the ecu into dumping fuel in which will actually dampen hp. (edited... sorry guys)
There's a lot of talk about air mods tricking the ecu into dumping fuel in which will actually dampen hp. Most guys running your mods on an mt are 300+
So lean is mean... Yeah. But rich is a b1tch so one way or the other if you're going to post your Dyno sheets maybe it might be worth giving a **** about the results.
Friend of mine did it... Osiris software I believe.
I have an 05 mt coupe I am planing to go taday later on to hp logic and tune the car with Osiris to see how much can I pull out of mu mods :
injen cold intake
kineteix manifold
borla headers
dc sports tp
borla exhaust
injen cold intake
kineteix manifold
borla headers
dc sports tp
borla exhaust
^ keep up posted on the numbers
OP good numbers, you def should tune it all nicely together, Im sure the car will run 100X smoother...
Also to the guy saying people are getting 300WHP with these mods and tune
that only happens if you dyno at Church dyno here in socal
^ yep Church is a shop, they just have a different dyno that reads higher than the dynojet that OP got on....
At Church shop, they use the dynapack dyno which reads highest, then its dynojet which is the most common one, then its the mustang dyno which reads the lowest...
So based on the numbers that OP has, Im sure he could be very close or over 300whp at Churchs dyno
Sorry guys- really overstated... thought for sure I'd read more 6MTs posting higher numbers but in my continued research I'm seeing a lot of 260-280 or so.
Apologies to the OP for being snarky. Posts edited.
The Z guys are doing something there on the 15th also.
