who has a tune?
Old Jul 7, 2012 | 02:16 AM
  #31
seymore4's Avatar
m56
They know what they're doing, should be awesome! Only disadvantage is that you don't get the cable... so you can't reflash back to stock or do anything yourself..
Old Jul 7, 2012 | 02:48 AM
  #32
Algy's Avatar
I cant even leave mine in Power or Eco mode. It just burns gas more than Stock mode..
Usually when I know Im going to get on it, I just switch it over to the Power map..
But usually I leave it in Stock mode when cruising. I hope it doesnt damage my engine for that it would be too lean.
I know for a fact from my commutes that Power/Eco mode burns more gas than stock.
Old Jul 7, 2012 | 01:03 PM
  #33
seymore4's Avatar
m56
could be that you were running too lean before the tune and even on the leaner economy map its still using more gas than before, can't really comment without seeing the A/F but its a very good possibility
Old Jul 16, 2012 | 05:18 PM
  #34
bluedevils95's Avatar
Getting my car tune today. My base line is 309 w/ just injen cai and FI exhaust. Now got the light weight crank pulley and FI HFC. What will my numbers be?
Old Jul 17, 2012 | 03:23 AM
  #35
Eno's Avatar
Eno
Ummmm... 309 with cai and exhaust? I want a few pulls on that Dyno.
Old Jul 17, 2012 | 03:41 AM
  #36
dofu's Avatar
20 Year Member
Exactly what I was thinking! I think he meant 209, but then again, he went to Church - his dyno is notorious for reading extremely high.
Old Jul 17, 2012 | 03:43 AM
  #37
But not high enough. But i am happy with my numbers for now.
Old Jul 21, 2012 | 12:19 AM
  #38
CPJ LB's Avatar
good info on the maps...thanks Seymore....
I keep mine in Performance mode....I recently went to Stock mode when getting my smog check done (and also took of the Berk HFC's)...didn't want to take ANY chances...
...which brings up a question, since I was tuned WITH the Berks then took them off for the smog...I will be putting the BERKs back on -- will I need to get re-tuned?? just checking....I haven't had the time to call or visit Shawn C....
Old Jul 21, 2012 | 12:35 AM
  #39
seymore4's Avatar
m56
If you had it tuned with the HFC on and you're putting them back on... it will run exactly like it did before you took them off... lol
Old Jul 21, 2012 | 12:54 AM
  #40
CPJ LB's Avatar
thanks...was on the lines of thinking that the ECU would adjust to the car not having the BERKS....I guess I was a little worried LOL....
Old Jul 21, 2012 | 12:56 AM
  #41
I thought the same thing too when i was getting a tune.
Old Jul 21, 2012 | 12:59 AM
  #42
seymore4's Avatar
m56
The thing about getting tuned is that you're changing the values that the ECU adjusts to in the ecu... so even if running with the cats on throws it out of whack and it can't hit the tuned settings its not going to be permanent, as soon as the HFC's are reinstalled it will start adjusting back to the tuned values. If you want to be extra sure you could do an ecu reset or clear the learned fuel settings in cipher
Old Jul 21, 2012 | 01:06 AM
  #43
Well if you have the different maps you can leave it in the stock settings.
Old Jul 21, 2012 | 01:10 AM
  #44
CPJ LB's Avatar
understood...
I'll be reinstalling the HFC's possibly this weekend -- or next...just been really busy....
Old Aug 10, 2012 | 10:24 AM
  #45
jninja26's Avatar
Your engine and/or tune has an issue if your getting worse efficiency with tuned map.
