03 5at de vortech dyno results
Old Feb 17, 2015 | 01:33 AM
es_bayy's Avatar
Had my car tuned via mac auto sports in parker, colorado. Not sure what to think of the tune so I need second opinions
03 coupe 5at
Car made:
356 WHP
303 TQ
3.12 Pulley
osiris Tuned
art pipes
Authentic hks hi power exhaust
Motor dyne 5/16 plenum spacer
Was hoping to get at least 370. Idk just feels like there is more left. Are these typical numbers for a 3.12 pulley ?
Old Feb 17, 2015 | 07:14 AM
ScraggleRock's Avatar
Well, every dyno is different as I understand, but I just looked up Parker, CO and it says elevation 5900'? That's crazy.
Anyhow, your elevation is gonna have something to do with being that the oxygen is thinner. Much less so than N/A, but still
What are you comparing it to?
Old Feb 17, 2015 | 10:19 AM
bluedevils95's Avatar
Elevation does play a big role. If you want to make the drive, I will be setting up another Dyno day in SoCal after my friend finished building his car. I am sure you will be in the 400s
Old Feb 17, 2015 | 10:30 AM
seymore4's Avatar
m56
That's over 1000 miles just to hit a dyno...
Old Feb 17, 2015 | 01:49 PM
es_bayy's Avatar
I understand elevation plays a role, however if it's SAE 1.23 corrected wouldn't that mean the elevation is accounted for?
Old Feb 17, 2015 | 02:05 PM
Texasscout's Avatar
You lose no boost, BUT, you lose "absolute" pressure. At 6000 feet there is 7+- psi LESS than at sea level. So, if you have 6 psi of boost, at sea level that's 6+14.7+ 20.7 absolute of boost. At 6000 feet you have 7.251886886510461 psi (approximately) of atmospheric pressure add 6 psi of boost and you get 11.25 psi of absolute boost, so you can see you lose A LOT of hp at that altitude.
Old Feb 17, 2015 | 02:16 PM
^what he said..haha
Old Feb 17, 2015 | 02:24 PM
es_bayy's Avatar
I see, so in essence if I were to get a dyno at sea level I should be seeing numbers in the 370+ range ? Does that affect torque numbers directly also ?
Old Feb 17, 2015 | 02:56 PM
Your numbers will all be on the +side.
Old Feb 17, 2015 | 05:01 PM
Texasscout's Avatar
Yes.
Atmospheric pressure, Temp (biggie), humidity ALL affect results to some extent. Not near as much on NA cars, but FI, it makes a very noticeable difference.
Old Feb 21, 2015 | 05:16 AM
es_bayy's Avatar
Yes.
I just have difficulty understanding what sae correction would mean. In parker colorado they use 1.23 correction, would that correction dyno be my estimated power at sea level? Or does it not take atmospheric pressure into account.
Old Feb 23, 2015 | 08:36 AM
Texasscout's Avatar
That's a +23% correction factor, I would think that it would correct for elevation.
seagrasser
May 3, 2022 09:43 AM
Thebaws11
Nov 30, 2016 12:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
9tray turbo
Sep 29, 2015 10:22 PM
