impressive dyno results
Old Jul 20, 2015 | 03:07 AM
sick_sixspeed's Avatar
okay so I got a baseline done on my 05' 6MT on a dynapack
then installed motordyne full lineup of parts 5/16 mrev2 art pipes and last but not least the tdxv2 also had injen cai already installed. so here's the aftermath after up rev tune.
as you can see 50+ hp and 50+ tq in the midrange from bolt ons is not bad considering I hear this is only possible from forced induction. what do you guys think of this? all input is welcomed.
Old Jul 20, 2015 | 03:58 AM
herrschaft's Avatar
Its hard to compare under the curve with a chart that isn't smooth. Your gains seem a little better than average but I wouldn't say FI territory.
Old Jul 20, 2015 | 04:13 AM
some guys with a hks blower barely see 60 hp increase. that is what I was referring to. and the chart is a little difficult to analyze but if you take the time to dissect it you can see their are more gains in the mid range than peak.
Old Jul 20, 2015 | 10:06 AM
herrschaft's Avatar
Those that are only seeing a 50-60hp gain with a supercharger are either doing it intentionally or their car is fvcked up.
I get the whole midrange thing but what I'm saying is the graph looks abnormal. There are some actual tuners on here so hopefully they can chime in since I don't know squat about smoothing or correction factors.
Old Jul 20, 2015 | 11:10 AM
bizkardi's Avatar
What all do you have done?
Old Jul 20, 2015 | 11:29 AM
Spartan268's Avatar
I noticed your dyno is from Churchs. Their dyno reads higher than normal compared to your typical dyno
Old Jul 20, 2015 | 10:02 PM
herrschaft's Avatar
^Thats true but he's talking about the gains, not peak numbers.
Old Jul 20, 2015 | 11:12 PM
rcdash's Avatar
Good gains 25 hp/ 40 tq (not 50+/50+). The values are a bit skewed coincidentally in the midrange because you have a valley and peak at the same rpm. Church's reads about 10% higher than a Dynojet. Looks like a healthy car!
Old Jul 21, 2015 | 12:30 AM
thanks for the input. if you look at 4.7k RPM's on both hp and tq charts to me it looks like an increase of over 40 close to 50 if not more. I understand there could be other factors none the less I am satisfied and preparing to go with a vortech setup soon.
Old Jul 21, 2015 | 01:17 AM
hurleyguys's Avatar
that is exactly what he was saying at 4.7K RPM there was a trough on your base line and a peak on your new numbers. so it might be a little skewed. usually the lines mirror each other except the after line in just higher up on the chart. but good gains.
Old Jul 21, 2015 | 03:23 AM
the bottom line is the stock baseline with just injen cai which was running lean and had slight pinging. middle line is baseline after mods with a/f ratio adjusted. top line is after full tune. *** you can see the middle and too lines do mirror each other.
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
9tray turbo
Sep 29, 2015 10:22 PM
