Uprev Anti-Lag not working
Old Aug 27, 2025 | 07:45 PM
Alexavier's Avatar
Mostly stock High Mileage G
I have gotten a tune on my 2004 G35 Coupe A/T, my anti-lag feature doesn't engage whilst im meeting all the requirements [above 30mph, above 3k rpm, engine up to temp] to do so, I have no dtc codes, and the ecm is reading the cruise control Cancel button is working when I press down, and my accelerator pedal meets the requirements for being fully depressed. Would there be any other reason this feature won't activate?
Old Aug 28, 2025 | 10:54 AM
seymore4's Avatar
m56
They didn't turn it on?
Old Aug 28, 2025 | 10:57 AM
Alexavier's Avatar
Ive contacted the tuner and they said they have turned it on, i forgot to add that my SET light blinks when I turn on cruise control and it won't engage, im not sure if those two things can be related. I've checked the stoppers for my brake and gas pedal and they're there and all of my steering wheel buttons work fine so I wouldn't presume the clockspring is bad.
Old Aug 28, 2025 | 01:14 PM
seymore4's Avatar
m56
Are you able to switch maps?
If your cruise control isn't working that could be an issue. I'd work with whoever did the tune to get it figured out
Old Aug 28, 2025 | 01:17 PM
Alexavier's Avatar
Yea i can change through my maps perfectly fine, I've checked with my scanner too that the ecm is reading and showing each button when I press them. My horn works too, all of my steering wheel functions work.
Old Aug 28, 2025 | 04:09 PM
G2B35AGN's Avatar
I wouldn't presume that. When the cruise failed on my 06 sedanX (RIP), everything else worked just fine and the issue was the clockspring. Not saying that's your issue, but I wouldn't discard it out of hand.
Old Aug 28, 2025 | 04:33 PM
Alexavier's Avatar
ahhh okok, is there anyway to diagnose if my clockspring is bad?
Old Aug 29, 2025 | 08:21 PM
G2B35AGN's Avatar
Troubleshoot using the factory service manual https://www.nicoclub.com/infiniti-service-manuals
Tunerz_Store
Engine-Vendor
16
Mar 24, 2013 10:19 PM
billybrun
14
May 17, 2011 02:01 PM
blew are sicks
Archived Sales
May 21, 2009 10:41 PM
sredish
V36 General Tech Questions
22
Sep 29, 2008 11:05 AM
