A-B-C pre-sets for radio,sat 18 total?
Old Jun 4, 2007 | 05:53 PM
new2G's Avatar
I programmed most of the pre-sets with XM stations thinking that XM, FM, each had 18 memory spots. This must not be true? When I push the FM button it still shown the XM stations on the right of the screen, but FM on the left as the source. Anyone understand my question or is it complete confusion? Thanks to anyone who might understand...........
Old Jun 4, 2007 | 06:11 PM
G-Whizzer's Avatar
No - not separate memory slots for each type... XM/FM & AM can all share the presets - so 18 TOTAL.
Old Jun 5, 2007 | 12:39 PM
new2G's Avatar
Thanks Whizzer..
Old Jun 5, 2007 | 01:32 PM
DJNOOCH's Avatar
G-Squad DJ =)
Yea I agree - 18 Total kinda blows
I mean XM/Sirius has 100+ channels alone - then theres your handful of FM's you'd want programmed and a few AM's for traffic/news/sports
18 is definitely not enough if you have SAT radio
Old Jun 5, 2007 | 07:04 PM
tgreenlv's Avatar
I agree that 18 isn't enough. As a compromise, when my favorite stations are adjacent, I'll set only one of them in memory. To access the other I just hit scan once, or hold the control on the left side of the steering wheel for the same result.
I have about 6 preset for my FM channels, and the rest are XM, which still falls short of what I would prefer.
Old Jun 5, 2007 | 08:07 PM
gustavo04's Avatar
Actually, there are 24 presets. You have your 6 in A, 6 in B, and 6 in C. Now, if you press your "Radio" button while on A, B or C, it will shuffle from XM, to FM, to AM and you can "set" each to a different station with the tuner ****.
For example, my Preset A is 1=XM20, 2=XM30, 3=XM47, 4=XM65, 5=XM90, 6=XM94, now when I press "Radio", my FM station is 106.7 and my AM station is 1070. However, if i press the up or down button on the steering wheel, it will scroll through the regular presets.
Hope this makes sense.
Old Jun 7, 2007 | 12:16 PM
new2G's Avatar
think I understand, i'll give it a try..............
Old Jun 7, 2007 | 01:08 PM
UltimateGee27's Avatar
18 is definetly not enuff. especially if you have xm..mine are as follows
a- all local radio stations
b- all sports from XM
c- news, comedy, weather from XM
i wish i had a D to put music presets from the XM
Old Jun 7, 2007 | 02:16 PM
hyukki's Avatar
How do you switch from A-B-C?
I can only use 6 presets.
Old Jun 7, 2007 | 03:55 PM
gstais's Avatar
Cool
You can either use the button marked "Preset A-B-C" on the head unit panel (it is to the right of the Off/On/Volume ****, or you can you voice command:
"Preset <A, B, or C>"
Hope this helps.
Old Jun 7, 2007 | 06:55 PM
DaCurryman's Avatar
I agree that 18 isnt enough, altho I make due pretty nicely with it.
Preset A: FM: 6 Local FM Music Stations
Preset B: XM: 5 XM Music Stations + XM Comedy
Preset C: Info: 5 Local AM News Stations + XM 211 (NYC Traffic/Weather)
It would be nice to have a Preset D or even E.
My main issue is that I wish there was a preset-toggle switch on the steering wheel. Right now, I can use the "Source" button on the wheel to change A --> B or B --> C, but if I want to go back to Preset A, then I have to use the "Preset A-B-C" button on the dash since the "Source" button on the wheel will cycle through the CD, CF, MB, Changer, etc.
Old Jun 7, 2007 | 09:56 PM
hyukki's Avatar
Hope this helps.
I was waiting for someone in my car and found the button for it. I feel so stupid.
Old Jun 27, 2007 | 05:54 PM
DLite's Avatar
I fear this is a stupid question, but how do you use the steering wheel controls to get to adjacent stations? I thought that the steering wheel control just flipped through the presets.
Thanks.
Old Jun 27, 2007 | 07:04 PM
GoofyG28's Avatar
Thanks.
You're right, you can't.
Old Jul 2, 2007 | 12:41 PM
DLite's Avatar
Originally Posted by treacherous
Actually just hold the tuning switch on steering wheel for a second or two before releasing and it will scan to the next tuneable channel.
Thanks. I got this to work perfectly for AM and FM.
However, XM appears to do something different. When I hold down the tuning switch, it changes to the next "bank" of XM stations. E.g., if I am on channel 100 (in the "World" section), it will skip all the way to 110, which is the first "classical" station. I can reproduce this behavior all the way through the XM lineup.
Is this the intended behavior in XM?
Dallsinghjr1
Sep 17, 2023 11:25 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Hogbone
Sep 28, 2015 06:44 PM
