Window problem
Old Mar 2, 2010 | 05:59 PM
wjc77's Avatar
Window problem
hey guys.
i have 2008 model and on driver side window, auto-one touch up/down window stop working.. auto down still work, but to raise the window i need to hold the button up...
anyone had same problem and got any idea if i can fix this at home?
i made appointment on this sat. to bring car to dealer..but i worry it will not be cover under warranty..normally window associated stuff is 1st yr or 12k miles..
Old Mar 2, 2010 | 06:38 PM
pinkii's Avatar
did you hold it down to long to dis-engage the control??? I did that once. So you have to either hold it up all the way for like 10 seconds or hold it down for 10 seconds.
Old Mar 2, 2010 | 06:50 PM
G35Now!'s Avatar
Moderation-free
SSSSEEEEEAAAAARRRRRCCCCCHHHHHHHHHHH....
Roll the window down, and continue holding the switch down for another five seconds. Then roll the window up and continue holding the switch up for another five seconds.
Voila, you've now learned TWO valuable things...
Old Mar 3, 2010 | 04:26 PM
docdom's Avatar
I have a 2008 G35x and happened to have the same problem but thought it was much worse about a month ago. I left my house in the morning to go to work, it was very cold outside and put my windows down to air out my car after smoking a cig. My front passenger window got stuck half way down and it would not go up or down. It was 11 degrees that morning so I was really upset and was ready to drive straight to my dealer. I waited 15 minutes then tried again and the window would go up and down but manually, the auto-roll up or down no longer worked.
I took my car to the dealer last week for my 45,000 mile service and informed him of the warranty work regarding the auto roll feature not working. He said it's not the motor, it just needs a reset. When I picked the car back up the auto roll now works fine.
mike730
Jan 12, 2018 04:25 PM
leo38cheng
Nov 12, 2015 06:49 PM
cmesidewayz
Sep 29, 2015 09:28 PM
gatorglaze
Sep 10, 2015 12:03 PM
Jnm07
Sep 5, 2015 01:16 AM
