A compact flash question...
Old Dec 31, 2010 | 03:07 AM
kool_yaar's Avatar
make sure the sd card is properly inserted into the CF and the CF into the car, if it still doesnt work then remove all files from card and add just one mp3 file to check if it reads it, if it works then it was just your music composition that had problems else it could be the card format or something around those lines.
Old Jul 8, 2012 | 10:19 PM
hrp783's Avatar
I got the adapter and a 16gb sd card. But it says "card reader error" don't know why. Does anyone have any suggestions??
Old Jul 22, 2012 | 01:38 AM
G3Sx's Avatar
You'd probably be better off just going with a CF card and use an adapter at home if your computer doesn't have a CF reader. Besides, a 16 gig card is way overkill as the car's CF reader will not see more than something like 512 files per card anyway. Mine is a 4 gig Sandisk Ultra and handles most mp3 and wav files with no problem.
P.S. Got any pics of the 12w7 enclosure, and how it fits in the trunk? After a year of running with a 13w7 ProWedge box, I finally had a custom one built to be able to get to the spare tire with the box in place.
Old Oct 25, 2013 | 09:47 PM
AustinBD's Avatar
Compact flash cover won't open
Hey everyone, I just bought an '07 g35s and it is loaded...however, I have tried to remove the cover for the flash drive but it won't come off...any suggestions or is that the only feature the car doesn't have? Thanks everyone
Old Nov 7, 2013 | 12:06 PM
Demandedace's Avatar
I had issues myself the first time removing my cover (two weeks ago), you really just have to get on the underside of the cover there is an opening, just pry it out with something blunt from underneath. You won't break anything, it's just a plastic casing, just be sure you don't bang up your dash or anything when it pops free. After it comes out it goes in and out easily, the first time is the roughest
Old Nov 7, 2013 | 07:12 PM
AustinBD's Avatar
Thanks for the help. It goes in and out quite easily now. Ok, that sounds bad...but eh...it's all part of it. Thanks again
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
Thebaws11
Jul 2, 2021 11:36 AM
Thebaws11
Nov 30, 2016 12:54 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Vqalexisz
Oct 14, 2015 12:48 AM
