2007 g35 sedan backup camera help
Old Jan 15, 2011 | 10:44 PM
SMOOTHDLR's Avatar
Hi, I have a 2007 G35 sedan with NAV AND BOSE, I went into the trunk today and removed the trunk panel, I notices that attached on the reverse light harness is an extra pin connector (see picture). I am guessing that this is for the reverse camera. Does anyone know if this is in fact the connection to conncet the reverse camera? Also will the reverse camera and chrome trim from a 2009 G37 sedan fit my 2007 G35 sedan? thanks
Old Jan 15, 2011 | 11:39 PM
AesonVirus's Avatar
An 09 chrome finish strip will fit your 07.
http://cgi.ebay.com/ebaymotors/NEW-I...mZ320635277211
Not sure on the wiring as I've never gotten in there an looked at mine.
Old Jan 16, 2011 | 12:06 AM
SMOOTHDLR's Avatar
thanks for the ebay link you saved me over 100 dollars on that piece.
Old Jan 17, 2011 | 10:48 AM
AesonVirus's Avatar
Send me $50- and we'll call it even
Old Jan 17, 2011 | 03:49 PM
RemmyZero's Avatar
i have an extra camera hanging around i was going to use for a project like that, never put it in though, but if you need pics of the harness let me know. i can't quite tell from your photo what you have but the stock harness is 4 pins, about 3/4 inch by 3/4 squared.
Old Jan 17, 2011 | 08:45 PM
borderline's Avatar
This connector may be for the optional spoiler unless you already have one installed.
Old Jan 18, 2011 | 08:54 AM
RemmyZero's Avatar
if the spoiler has a light then it will have a two pin connector, power & ground.
Old Feb 12, 2011 | 02:17 PM
viztang's Avatar
Could anyone by any chance figured out this? I think I have the exact setting as yours, which is a 35 with boss and nav. I would like to purchase the trim and camera if this works for them. Longing for a backup camera for a while. !!
Thanks!!!!
Old Feb 12, 2011 | 03:18 PM
viztang's Avatar
I just did some investigation myself, and removed the trunk trim. So I see there is a four pin connecter sitting quietly along with the other cables.
A close picture, macro shot, reveals that it has two pins and two connecter hole. Could the master confirm this is the right connector for a backup camera? If so, I think I would purchase one and test it out for reals.
Also, question, how can I tell if the car's steering wheel comes with the rotation senor (or names in something else) that detects the direction of the vehicle? Or I am completely out of luck for this?
Thanks!
Pics in attachment
Attached Thumbnails 2007 g35 sedan backup camera help-img_3280.jpg   2007 g35 sedan backup camera help-img_3277.jpg
Old Feb 13, 2011 | 11:31 AM
RemmyZero's Avatar
well unfortunately that does not appear to be the backup cam connector. i double checked the camera i have from an m35 and it has 4 pins, so the mating side on the car would need 4 holes. that very well may be for a spoiler or something else, not sure though....
as far as checking for a rotation sensor you would need to remove the plastic trim around your steering column then just look for the harnesses. use this thread to remove the trim:
https://g35driver.com/forums/v36-diy...t-paddles.html
im not 100% sure offhand what the sensor/harnesses look like but the manual should have it in there, otherwise i'll look for you this afternoon.
don't lose hope though, i don't know alot about the model you have but i would like to believe the backup module harnesses were included with the nav model....
Old Feb 20, 2011 | 11:03 AM
RemmyZero's Avatar
i think there is a control unit on ebay for cheap right now if you want to grab it. also i have a backup camera for sale which should work, although you'll need the spoiler trim for it.
Old Mar 16, 2011 | 02:19 AM
Da_KiiD_cT's Avatar
can someone confirm if this works????
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
laksjd84
Jul 24, 2015 05:12 PM
