AUX Input - Analog to Digital Conversion
Old Aug 24, 2011 | 03:07 PM
HumanCaviar's Avatar
Cool AUX Input - Analog to Digital Conversion
Vehicle & Options:
-2007 G35x Sedan, No-Nav
Work Done:
-Parking brake and VSS by-pass to allow AUX video while driving
Wishful Thinking:
-Solder & wire Component Video leads from existing control unit (for a lack of better terminology) to the center console. The aim is to display a cleaner digital video signal on the AUX channel. I realize that I am no electrical engineer / Video encoding expert, so let me know if I'm being unrealistic.
In Closing:
-Thanks for reading my post! Please feel free to respond simply with interest in the project or other cool & recommended DIY Mod projects.
Old Aug 24, 2011 | 03:33 PM
RemmyZero's Avatar
you can display component video on the screen but you would have to convert it to RGB (remember, component video is not exactly the same thing) then you'd have to just tap into the RGB inputs (which is easy). so first things first is to get a converter, then you can install a switching relay and the YPbPr jacks in the console.
Old Aug 28, 2011 | 09:42 PM
apexi957's Avatar
The converter itself is expensive...it could range from $80+ easily.
Old Aug 29, 2011 | 01:18 PM
RemmyZero's Avatar
it can be expensive, you can also comb ebay for deals, sometimes they pop up cheap. also check craigslist, buy.com, etc.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
dseet
Oct 11, 2015 12:40 AM
6spdGspot
Oct 5, 2015 01:55 PM
