Sub cuts out
Old Jun 9, 2013 | 05:33 PM
Lurkin07's Avatar
Sub cuts out
Hey...I had a sub installed in my non Bose v36 an occasionally the sub stops hitting on it's own. It may restate after I turn off the vehicle and sometimes it takes a couple restarts. Also, the amp is receiving power while this is happening and even when the sub is normal, if I turnoff te engine and keep the stereo going, the sub no longer bumps. Thanks in advance to any reply...unless it's mean haha!!
Old Jun 9, 2013 | 06:13 PM
SergeantRed's Avatar
This is going to take a while because I have several thoughts. Lets keep it simple to start... Are you using a line output converter (LOC)?
Old Jun 9, 2013 | 06:38 PM
Lurkin07's Avatar
Yes I am.
Old Jun 9, 2013 | 07:55 PM
Check the connections of the LOC to the speaker lines and check that the RCAs are tightly seated. If either is loose then you'll get a break in music.
Old Jun 9, 2013 | 08:03 PM
Lurkin07's Avatar
Awesome I'll do that. Thanks man!! If not...crap, I'll Pm u if that's ok haha
Old Jun 9, 2013 | 08:18 PM
No, I prefer to keep it on this forum so others can discover the solution as well when they have a similar issue. However, if you need to ask something not pertinent to this thread, then you can PM
Old Jun 10, 2013 | 01:56 PM
Lurkin07's Avatar
Nothing is loose...it cut out again while i was driving and I restarted the car twice then it came back.
Thebaws11
Jul 2, 2021 11:36 AM
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
JustinMKN1
Sep 18, 2015 03:40 PM
