2008 oem back up camera
Old Mar 15, 2014 | 05:32 PM
kelvin21's Avatar
Help!! 2008 oem back up camera question
I just recently picked up a 2007 g35x tech package fully loaded the previous owner of the car had bought a used 2008 back up camera with the trunk lid and also the module/harness and wires for the 2008 model i cant seem to find a wiring diagram to see where all the wire plug into does anybody have pics or info on this because im pretty sure it can be done since the 08 model has the same nav and headunit?
Attached Thumbnails 2008 oem back up camera-img_1995.jpg   2008 oem back up camera-img_1996.jpg
Old Mar 22, 2014 | 07:05 PM
RemmyZero's Avatar
Well it looks like you have the camera control unit and everything you need there. If the head unit is the same then you should be able to plug and play the camera. The manuals are here (click link below), courtesy of another member. Just go to the AV section.
http://www.nicoclub.com/archives/use...-database.html
Old Mar 24, 2014 | 09:54 PM
kelvin21's Avatar
thanks for your help really appreciate it do you know anybody who sucessful has done the install once again thanks for the help
Old Mar 25, 2014 | 12:17 PM
RemmyZero's Avatar
I could have sworn one or two members here or on myG37 have done it. Did you do a search yet? Just google "camera" and "myG37" or "g35driver" and you'll get a bunch of results. I thought one member just installed the stock camera last summer. The only issue is that the camera control unit also uses the yaw sensor in the steering wheel for input so you won't have the active lines that move to show you your projected path as you turn the steering wheel but in my opinion having a backup camera is well worth it either way.
rping
Jul 26, 2015 09:53 PM
apintojr
Jul 23, 2015 10:52 AM
crazy_g35s
Jul 20, 2015 02:30 PM
newbdriver01
Jul 15, 2015 06:10 PM
