2008 g35x No audio!
Old Mar 17, 2014 | 03:02 PM
SwissQ's Avatar
2008 g35x No audio!
Hello everyone,
new member to this forum and a new infiniti driver also!
Anyways so heres the story, having my car for about a week I drive to the plant site I work at where there are no plug ins for my block heater. At the time it was around -35 Celsius and working for 12 hours, my battery crapped out (right before I was planning to replace it)
So some guys come to help with boosting my car, I was in the drivers seat and they were hooking everything up. Well one of the guys messed up and hooked the batteries incorrectly (opposite leads) and blew fuses. After that my smart key wasn't being recognized by my car so I had to tow my g which I had for only a week (it really sucked) to the dealership.
At the dealership they changed out the fusible link, allowing for my smart key to work properly, car was running fine and no problems with using the key.
Only problem now was that they found out my headlights were out and there was no audio.
They check everything out and find out a fuse blew for the headlights, changed that out and everything was good. I had to go back to work (this being a few days later) so I took out my car with no audio
On the deck everything is fine, it shows that I am connected to a radio frequency and also show what song is being played (no radio problem). When I put the volume up and down nothing happens ( I hear no cracks or any noise at all). Tried putting in a CD and used the AUX cord on my ipod but again nothing. My stock bose audio setup was perfectly fine before the boost.
I checked out the audio fuses on the drivers side kick panel, and next to the battery, changed them out to see if it had any luck but still nothing. (fuses looked like they were still good even though I changed them out)
Anybody on this site have a similar problem or might know a probable cause and fix? I thought Id try this forum first before heading back to the shop just for audio, really would appreciate it
Oh ya, forgot to mention that everything else electronic is working fine like climate control, seats, etc.
Old Mar 18, 2014 | 12:24 AM
colin.ssc's Avatar
I have an issue with my audio...some days when I start the car, no sound comes through...everything is on, but like you says volume up and down but no sound. If I turn off the engine and start again, audio would work fine...not too sure what the problem is
Old Mar 18, 2014 | 12:58 AM
SwissQ's Avatar
Yeah I tried switchin the car on and off with the engine and thru just switching it to acc but no luck with any audio at all since the incident
Old Mar 22, 2014 | 07:02 PM
RemmyZero's Avatar
Do you have the Bose system? You may have blown the amplifier fuse. Double check all your fuses to be sure.
Old Mar 23, 2014 | 03:33 AM
SwissQ's Avatar
Yep I have the stock bose system, I'm not too familiar with G's or pretty much any audio setup so I wasn't too sure what to look for.
I was talking to other people though and they did say to check for the amp fuse. Would that be right on the amp or is it located somewhere else
Old Mar 23, 2014 | 05:02 AM
SwissQ's Avatar
Oh nevermind found it, missed it the first time I went through the drivers side panel
Old Mar 23, 2014 | 07:50 AM
SwissQ's Avatar
-fixed
Burnt amp fuse
Old Mar 25, 2014 | 12:17 PM
RemmyZero's Avatar
Originally Posted by SwissQ
-fixed
Burnt amp fuse
BAM! glad to hear you got it fixed.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Claudiu
Sep 26, 2015 01:04 PM
