Data Base: Lowered with Aftermarket Rims/Tires
Old Jul 23, 2008 | 02:49 AM
  #61
mzhu35s's Avatar
Tire size
Sup guys, should i go with 245/40 or 35/19 in the front? I'm looking in getting some 19 x 8.5 Volks. Any help would help, thanks.
Michael
Old Jul 23, 2008 | 10:38 AM
  #62
sredish's Avatar
245/40. the 35's just look too small and mismatched with the car. and the 40's match the 275/35 rears perfectly. everyone thinks the sidewall is bigger on the 245/40s but it ends up matching perfectly.
here's a pic with 245/40s and 275/35s on 19s.
http://www.redishconstruction.com/im...Car/Shoes1.jpg
Old Jul 23, 2008 | 07:48 PM
  #63
mzhu35s's Avatar
Do you get any rubbing with 40's in the front?
Old Aug 7, 2008 | 04:52 PM
  #64
SVLRx's Avatar
what lugnuts are y'all using on your aftermarket wheels? Can you use the factory ones or do you have to buy new ones? Curious b/c i just bought Sevas but haven't mounted them yet...
Old Aug 7, 2008 | 05:09 PM
  #65
GEE35FX's Avatar
The stock OEM lugnuts will not work with most aftermarket wheels, because of the built in washer. You should purchase aftermarket wheel nuts and locks for your new wheels.
Old Oct 14, 2008 | 07:59 PM
  #66
Wes_888's Avatar
Hey guys... are 32.8 lbs heavy for 20x9 rims?
I know the stock 17's are 30lbs and the 18's are 32lbs.
Old Oct 14, 2008 | 08:28 PM
  #67
GEE35FX's Avatar
Wes, I don't know where you got those weights but those weights seem extremely heavy to me.
Old Oct 14, 2008 | 08:32 PM
  #68
B L U E S L A T E's Avatar
Honda Accord
My T1S is about 25lbs for the 20x9.5 and about 23lbs for the 20x8.5.
Old Oct 14, 2008 | 10:33 PM
  #69
terrycs's Avatar
The rotational moment of interia also depends on where the weight is located.
Unless you plan to do a lot of tracking ... don't worry about it. Get the wheels that looks good to you.
Old Oct 14, 2008 | 11:09 PM
  #70
Wes_888's Avatar
those are the #'s I read from one of the threads... so I cant verify if those weights are correct except the 20x9 rims that I am inquiring about.
Old Oct 14, 2008 | 11:13 PM
  #71
Wes_888's Avatar
blueslate - wow... the rims that im thinkin about are so heavy compared to yours... are yours forged? the ones im asking about are cast.
terryc - thanks. Ideally, I would prefer lighter and forged rims... but.. money is an issue... :S I would love to have the SL-5 DPE's... those are sick.
The 20x9 rims im thinking about are the vossen vvs-082 rims.
Old Oct 14, 2008 | 11:19 PM
  #72
GEE35FX's Avatar
I thought the stock OEM 17s for our car was around 23-24 #s and I know the Coupe !9s weight 21# for the rear and 19# for the front.
I believe my 18 x 8.5 cast PIAA wheels are 26#s.
Here is site with lots of wheel weights. It isn't complete , but will give you an idea of weights.http://www.wheelweights.net/
Wayne
Old Oct 14, 2008 | 11:30 PM
  #73
Wes_888's Avatar
oh thanks wayne. Im gonna check that out =)
Old Oct 20, 2008 | 09:23 PM
  #74
d_cecc629's Avatar
Hey guys. I'm puttin a set of 20's on my X soon and i just wanted your opinion on what's the best tire size for the fronts and rears. Also i really wanted to put 20x10's in the back but you can't do that on an X right?
Old Oct 20, 2008 | 09:48 PM
  #75
Honda Accord
Some teasers coming up soon....
